Man I could use some help...
Please can anyone help. Thanks for your time.
I started the car at 8:00am, went to run errands and got back home at 11:30 am. The car started fine when I left to go back home. At 1:30pm I was going to leave again. I tried starting the car. It sounds like the car wants to turnover. No clicking, just like a regular start but doesn't. After the car tries at least 6-8 times it just stops.
I last got the alternator changed in 11/2008 and at the time the shop I took it to said the battery was fine. I'm not ruling the battery out as a possibility since its the original from when the car was made. Unfortunately, I have a volt ohm reader and do not know how to use it or to even know what level the battery needs to be at.
It is likely you need a new battery. Yes, a load test will be definitive, but the voltage drop has helped me in the past. Anything under10.5 volts is a replacement battery.
Ed
When you said that it would turn over 6 times and stop - were you using the touch start feature or holding the key? Either way, if it's turning over every time the battery is more than likely fine.
What exactly are the "alternatives" about replacing a battery well before it needs it? These OEM batteries (mine's 5 years old) last a long, long time. If it goes bad, there's always roadside assistance.
When you problem solve, sometimes you go through the easy solutions.
Somewhere on this site is a DIY on the crank position sensor. Not a hard fix, this coming from someone who has never done it....
Ed
BTW a volt meter isn't really needed if you can access dyno mode. This is for diagnostic purposes and is accurate.. IIRC someone on here has confirmed it does load the battery.
