Official C-Class Picture Thread
#1101
05 C230K SS and 02 C240
inFiniTE LooP , those are TSW Bremma F 19X8.5 and R 19X9.5...NO SPACERS NEEDED on an 05 C230K SS. Here's the same pic of my dirty car but different day time
#1102
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
did you change the suspension at all, or is that stock?
#1104
2005 Obsidian Black C230 Komp Sports Sedan, 2006 Iridium Silver ML350 SUV
essa, i was gonna ask the same thing... stock suspension setup? looks great!! and how much the wheels/tires combo cost you?!
#1105
2005 Volvo S40 T5 AWD, 2004.5 C230 Sport Sedan, 2005 E320 CDI, 2008 C300 4-Matic Luxury
#1106
blkc230k,
TSW Bremma 19x8.5, 19x9.5 with nitto nt555 235/35/19, 265/30/19 mounted, balanced, lug nuts shipped to your front door for less than 2K.
I bought them through Neal (BlackC230Coupe), also a member from tMBWorld.org or you could send him an email to: BlackC230Coupe@ aol.com
I like them because I don't have to use spacers for 05 C230K to clear the sport caliper since I don't want to spend so much on HRE or Iforged. Most wheels around that price will required spacers and most spacers cause vibration.
inFiniTE LooP,
I would like to raise the rear by 10mm to 15mm, because right now with 2 grown adults on the back, will rub when you hit a dip and you're going over 65mph. With 2 petite chixs on the back seat, it's fine.
inFiniTE LooP,
#1107
'09 A4 S Line
essa: Did you try changing the rear spring pad to #4 (thickest)? That should help a bit if you haven't already done it. Your car looks great, btw.
#1108
Blake P , thanks..
#4 pad is 17mm and I'm using #2 which is 9mm. I will only get 8mm...I need more than that so my rear fender will be sitting right at the top of the wheels instead of being tucked in ...like right now.
#1109
'09 A4 S Line
Sounds like changing the pad or changing your springs for coilovers are your only options, unless you can get someone to fab thicker spring pads.
#1110
Too many to list
#1112
diamondblak05,
The ride quality is almost the same....but you feel a big different on your steering wheels. It's more responsive and you could almost feel the the roughness of the road you're driving. When you change the springs....it makes a huge different. Stiffer and less tolerence for bump and dip but not bouncy
mj50,
thanks for the compliments
mj50,
#1113
Former Vendor of MBWorld
Originally Posted by diamondblak05
Also, where did you bought them from? Thanks.
