Catalytic converter problem!
Old Feb 16, 2010 | 09:03 AM
chrlbake's Avatar
2009 C350
Hey Guys, last year I posted on here about an exhaust noise coming from beneath the passenger seat area/under gearbox. It happened after I was stuck over in a foot of snow. There was some speculation that this was caused from hot exhaust being packed with cold snow.... causing welds int he catalytic converter or just somewhere in the exhaust to break. From outside the car, there really is no noticable problem, just loud on the inside, especially when the car is cold and worse when it is colder outside.
Basically, I think I need a new catalytic converter/ cat back exhaust maybe. Does anyone have a stock exhaust they would be willing to sell?? I drive a 2005 230 SS, but would actually prefer the 2006 or 2007 exhaust.
I live in Indianapolis, IN and would also be willing to pay someone for their time/expertise to help me out with this!
THanks for reading!
Chris
Old Feb 16, 2010 | 11:52 AM
MBfinatic's Avatar
e36 318i, 2004 sti
is there a rattleing noise when you accelerate?
Old Feb 16, 2010 | 12:21 PM
SickSpeedMonte's Avatar
2007 C230 and 1985 Monte SS
Why not just take to to an exhaust shop and have them re-weld it for $20?
It would save you a ton of time, money, and aggrivation if its simply a busted weld.
Plus, if it's not a broken weld, they might be able to tell you what it is and save you from throwing parts at the problem.
Old Feb 16, 2010 | 01:01 PM
chrlbake's Avatar
2009 C350
wouldn't the broken weld be inside the converter and not reachable? Also, i've taken it to 2 dealerships and a mercedes service shop and they couldn't figure it out. Said I had to wait until it got worse. If i could get a used stock exhaust, I would jsut swap it all out..... It has to be coming from somewhere at either the cat or back..
Old Feb 16, 2010 | 02:04 PM
MBfinatic's Avatar
e36 318i, 2004 sti
just remove ur secondary cats. if that is the problem.
Old Feb 16, 2010 | 04:43 PM
chrlbake's Avatar
2009 C350
if i remove those then wouldn't i have to weld a pipe in its place?
Old Feb 16, 2010 | 05:03 PM
MBfinatic's Avatar
e36 318i, 2004 sti
yep. shouldnt be to hard. I had it done a couple months ago.
Old Feb 17, 2010 | 05:22 PM
Smallbodybenz's Avatar
2002 c230 coupe
THanks for reading!
Chris
WOW very ironic!! I have the same exact problem after taking it to many shops around town Here in Indianapolis,IN I've been trying to figure my problem out and mechanics have told me that i have to wait till it gets worse also.. I am also going to be looking for new CAT.. I would have it taken off but here in Indiana but i am pretty sure it is illegal to have them off so no shop will do it ...
And CHRLBAKE if you find someone around here willing to do some welding on the side please let me know , I am also willing to pay for service thanks!
Old Feb 17, 2010 | 05:26 PM
2002 c230 coupe
JW you said you had this done a few months ago.
Were you having similar problems? and did it take care of it?
Old Feb 18, 2010 | 07:41 AM
I dont believe that there are baffels inside of the convertor that would cause any loud exhaust noise if they were damaged. The cat is just a "resevoir", so to speak, with a catalyst material inside of it. They could cause a rattling sound.
What kind of noise is it?
Old Feb 18, 2010 | 09:02 AM
MBfinatic's Avatar
e36 318i, 2004 sti
no the problems were not similar. i only removed the secondary cats since they dont have 02 sensors and the left one was rattling really bad.
Old Feb 18, 2010 | 11:17 AM
2002 c230 coupe
It sort of sounds like an exhaust leak.. I hear it right underneath my seat. I especially hear it when i accelerate really fast. The best way i can describe it is when you put a baseball card in a bike wheel, just like how we all use to in the day. haha
And as long as there is no O2 sensor after or at the CAT there shouldn't be a CEL light on if i remove the CAT right?
Old Feb 18, 2010 | 11:59 AM
MBfinatic's Avatar
e36 318i, 2004 sti
yes sir. ya u can hear it a lot when u accelerate. there are 2 sec cats. just find a shop and have them put on a straight pipe. there wont be a light and u will still pass inspection.
Old Feb 18, 2010 | 02:39 PM
chrlbake's Avatar
2009 C350
does anyone have any pics of the exhaust and point out what should be replaced with a pipe?? I don't have jack stands at my house here, everything is down in south carolina at my parents... therefore i its very hard for me to even see the exhaust and that makes it hard for me to diagnose where the source of the problem is. I just think it has to be exhaust related....
Old Feb 18, 2010 | 05:31 PM
2002 c230 coupe
Basically what im planning on doing is removing the CAT (#20) from my exhaust and then getting a straight pipe back.. The only prob is that in Indiana im pretty sure it is illegal to remove the CAT (#20) so im looking for a shop that may do it on the side. Should not be no then 50-75 dollars total
Old Feb 19, 2010 | 04:49 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Try driving one wheel on a high curb or bank then you should have enough room to crawl under & inspect your cat.
Old Feb 26, 2010 | 02:38 PM
2002 c230 coupe
I went to muffler shop to get my cat removed because of the noise it was making and they said they could do it but it would cause a CEL to come on due to a O2 sensor after the CAT..
Im not really wanting to deal with that so i opted out so....
Im really stumped, i really cant see my self buying a new exhaust. Does anybody have any suggestions or solutions thanks!
