Supercharger Boost- 32 lbs
Rating: Thread Rating: 6 votes, 5.00 average.
Old Mar 2, 2010 | 10:42 PM
Vermicryx's Avatar
02' C230; 88' Camaro
I removed my Supercharger intake, without much surprise i wasnt getting any boost. The car's S/C whine was rediculously loud. My brother and I was trying to find a way to still have the boost and the sound at the same time. Soo, we wanted to see what we could do by just covering the tube up. We turned my car on and in idle i was already at 5lbs of psi... it dropped to 3 psi in reverse and when i shift to first i hit only about 2000 rpms when my boost gauge literally shot to 32+ psi and it blew off my S/C tube that my boost gauge was hooked into.. my car then died and i turned it off and checked our DIY clogging... it was fine.. :\ i then realized that it wasnt that it was the tube for my intake.. lol so any ideas that will allow me to continue at 12 psi and keep the sound?
Old Mar 3, 2010 | 12:21 AM
Dr.Fox's Avatar
2013 C300 4Matic Sport
Put everything back together like it was from the factory, and get a larger crank pulley. How are you at 12 psi in the first place?
Old Mar 3, 2010 | 12:37 AM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Mine consistently pumps about 69 inches of mercury absolute without any unbecoming noises.
Pictures of your '88 F-body?
Old Mar 3, 2010 | 01:24 AM
Vermicryx's Avatar
I replaced everything back to standard after my tube jumped out lol. Tomorrow morning i can take some pics of the camaro.
With all the pieces removed do you have any idea why my engine sound is SOO much deeper?
Old Mar 3, 2010 | 03:28 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Isn't the factory kompressor putting out 11-14psi or somewhere in that range? That was my understanding.
Old Mar 3, 2010 | 06:19 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
i think it's 11psi for stock m271 230k. not sure about the m111. might have been 11-12psi as well.
and to OP, I think you have the boost gauge connected to the wrong place or your boost gauge does not adjust to atmospheric pressure. any supercharged/turbocharged engine should have a vacuum (neg pressure) when idling.
Old Mar 3, 2010 | 09:35 AM
LinDenKid's Avatar
C230 coupe 2002
Sorry to jack your thread , but where can i find the asp pulley for a good price? Also i believe asp only makes a crank pulley , what about the s/c pulley?
Old Mar 3, 2010 | 10:25 AM
Dr.Fox's Avatar
I wasn't aware these engines had that much boost stock.
Linden, ASP's pulley is a crank pulley. The larger diameter crank pulley results in more boost. Larger crank pulley diameter = effect of smaller s/c pulley diameter.
Old Mar 3, 2010 | 12:17 PM
Vermicryx's Avatar
Yes, mine shows vacuum, before we sealed that hole i get like .5 vacuum and -1 when first throttle then it goes up till 3.5rpm and it stops rising, then it will go a little higher when i hit 5 My boost gauge works np
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
