help with rims
Old Mar 3, 2010 | 12:59 PM
CFM's Avatar
CFM
2004 E240
help with rims
good day guys,
i need help with my car. will i have problems if i use 19x10 offset 30 or 32?
any rubbing problems or fitment issues?
tia
Old Mar 3, 2010 | 01:28 PM
BigBodyBenzC240's Avatar
...a panty dropper...
Looking at your personal info it says you drive an E240 so you would get a better answer in the W211 section on this forum.
Old Mar 3, 2010 | 01:31 PM
CFM's Avatar
CFM
2004 E240
sorry its for my wife's w203 just want to know if there will be any fitment issues.
Old Mar 3, 2010 | 01:40 PM
e1000's Avatar
a quarter mile at a time
19x10's are going to be a tight fit.
Old Mar 3, 2010 | 01:43 PM
They will be a tight fit but with a +36 rear offset they should fit with no spacers on a sedan.
Old Mar 3, 2010 | 01:49 PM
CFM's Avatar
CFM
2004 E240
how about offset 30 or 32??
Old Mar 3, 2010 | 02:38 PM
e1000's Avatar
I'm going to defer to Frank on this one, 19x10's are just a real close fit on these cars. I'm sure you know this already but this is only for the rears.
Old Mar 3, 2010 | 02:46 PM
Nokiemon's Avatar
CLK55 AMG, SL55 AMG, C55 AMG
A lower offset, 30 or 32 on the rears will push the rim out at least flush with the fender. Better to go with a higher ET on the rear, and 19 x 10's will cause huge issues if tried to fit on the fronts.
Old Mar 3, 2010 | 02:51 PM
MiKeSSw203's Avatar
From: South Coast Metro/Cerritos/Yorba Linda California
'05 C230K '10 GLK350 '13 SMART
You'll need to roll fenders with 265/30 tires. How much rolling will depend on how low you are and tire selection. +35 on 19x10 is easier to fit tho. I'm currently running +33 19x10 265/30/19 Toyo T1r's.
Old Mar 3, 2010 | 02:52 PM
MiKeSSw203's Avatar
oh yeah hope you aren't trying to put 19x10's up front
Old Mar 3, 2010 | 07:29 PM
CFM's Avatar
CFM
2004 E240
its for the rear, 19x10 offset 30. the front is 19x8.5 so im sure there will be no problem with that my only worry is with the rear.. not sure if it will fit the car will be dropped with h&r springs only.. dont have time to pick up rims and try it out thats why im asking for your help. dont know much about w203 just got the car im using my w211. if the 19x10 rims fit my w211 perfectly will it also be a perfect fir for the w203??
Old Mar 3, 2010 | 07:30 PM
CFM's Avatar
CFM
2004 E240
by the way the tires are bridgestone 275/30/19
Old Mar 3, 2010 | 09:51 PM
e1000's Avatar
No
IMO, 19x10 w/ 275's won't fit.
Old Mar 4, 2010 | 12:52 AM
dlwiser's Avatar
C32 AMG
yes it will, not advisable, but it will.... even lowered with +30. BUT you better get it on a rack and set a few degrees of camber. but if you HAVE to make them work, from experience, they will.
Old Mar 5, 2010 | 01:42 PM
Mu9enx's Avatar
01' C32o
Put some spacers on that itch, drop the offset down to 18, and go hellaflush.
