belt size
Old Mar 21, 2003 | 07:30 PM
boylinator's Avatar
2024 GLE450W4
belt size
What size belt goes on the factory pulley?
Old Mar 21, 2003 | 10:15 PM
Buellwinkle's Avatar
Which belt? The S/C belt is 1355mm or about 53 3/8".
Old Mar 21, 2003 | 11:36 PM
boylinator's Avatar
2024 GLE450W4
I'm trying to find the size of the factory belt that i took off to put on the asp pulley.
Old Mar 22, 2003 | 12:29 PM
I'll try again to see if you are paying attention this time. The S/C belt is 1355mm or about 53 3/8".
Old Mar 22, 2003 | 12:36 PM
boylinator's Avatar
2024 GLE450W4
you asked which belt and i was trying to tell you which one i needed the size of. i didn't know if it was the s/c belt, only that it was the one i removed when i installed the asp pulley. my knowledge in this area is very limited.
Old Mar 22, 2003 | 12:46 PM
boylinator's Avatar
2024 GLE450W4
i can only find a 53" and a 53.7"..........know where i may be able to get one
Old Mar 22, 2003 | 06:27 PM
Matt230K's Avatar
2010 C300 4matic
At your dealer.
Old Mar 22, 2003 | 11:54 PM
Originally posted by Matt230K
At your dealer.
You're giving away all our secrets about getting parts at the dealer. I had everyone convinced you can only get cookies and car washes there.
BTW, if you go to the website for Gates belts and select the most current Mercedes they have, the 2001 SLK230 (same motor as us), they show a 53.2" alt - s/c belt, part number K060532 and that's close enough to the 53.3" factory belt.
Old Mar 23, 2003 | 12:46 AM
Matt230K's Avatar
2010 C300 4matic
You can't get parts at my dealer. Well, at least not without waiting for them to order it. And then you will have to wait longer after they re-order it because they ordered it wrong. Service dept. is bad enough, but it seems worse when you can't get the parts you need.
