Replacing Battery
Old Mar 8, 2010 | 08:35 PM
damedash's Avatar
c240
Replacing Battery
im planning to replace my stock battery, (c240 2004) with a yellow top optima battery(planning on putting a new sound system in). but i have searched the forums and i cant find the specs on the stock battery to help choose the right yellow top battery. which yellow top battery should i get that would fit?
here are specs on yellow tops:
http://www.optimabatteries.com/optim...wtop/specs.php
oh and where can i find some cheap windshield wipers for the c240??
Old Mar 8, 2010 | 08:54 PM
ontmiss's Avatar
2007 C280 4matic Avantgarde
http://www.rmeuropean.com/mercedes-parts.aspx#MakeYear
Old Mar 8, 2010 | 09:16 PM
damedash's Avatar
c240
thanks
Old Mar 8, 2010 | 09:25 PM
acr2001's Avatar
2012 C300 4Matic
You will not find an Optima battery that meets or exceeds all of the specs of the OEM battery. They do not make one. OEM battery FTW.
Old Mar 8, 2010 | 10:05 PM
Moviela's Avatar
If your battery is bad, call roadside. You will be money ahead. They install the correct battery and reset the computers for only the price of the battery. If you go to the dealer, you will be charged for the installation labor too.
The Benz OEM battery is larger than those usually found in the aftermarket. Optima battries are OK for racing, but they are no better than the OEM battery. In your car every available Optima battery is undersized. Your sound system will be fine with the OEM battery.
Old Mar 9, 2010 | 12:11 AM
bdgdl08's Avatar
1999 CLK320 (sold), 2007 C230 SS (gone), 2000 Grand Marquis, 2011 CR-Z, stay tuned...
Your sound system will absolutely be fine with the stock battery. Roadside is the way to go.
Old Mar 9, 2010 | 12:25 AM
samaritrey's Avatar
Super Moderator
THE C350
+1 that is what i did.
Old Mar 9, 2010 | 12:37 AM
aznstud510x's Avatar
2005 C230 Kompressor Sedan
For those of you who called roadside, how much did it cost for the replacement?
Old Mar 9, 2010 | 02:01 AM
samaritrey's Avatar
Super Moderator
THE C350
cost of battery i think 145 for me. i gave the tech a nice tip though. so like 165 i think it is in a thread i made somewhere. but the tech spent like an hour answering other questions i had and was a really nice guy highly recommend it.
https://mbworld.org/forums/c-class-w...ttery-lol.html
Old Mar 9, 2010 | 03:29 AM
damedash's Avatar
c240
ok thanks everybody...has anybody done a DIY on changing the Big 3? alternator, ground, etc etc
