Key Battery?
Old Mar 23, 2003 | 11:09 PM
jasonrosen's Avatar
Key Battery?
so friday night i go to lock my coupe and the chirper doesnt worki finally keep pressign it and it works but the light flashes verry dull red like it was week... so it finally stops working. when i hit the buttons no LED light... my other key works fine... in the weeks leading up to this my key had limited range
1. Is it the battery
2. If it is how do i replace/get it replaced
Old Mar 23, 2003 | 11:14 PM
Matt230K's Avatar
2010 C300 4matic
It sounds like it is the battery. It should still work to start the car though, did you try that? If it works, then it is just the battery. If you take it to the dealer, they will have the right batteries and will probably put it in for you.
Without going to a dealer, pull out the metal key and right before the key comes all the way out, there is an edge where you can use the tip of the key to pry the end cap off of the key. Once it pops loose, pull it out by hand, and there will be two watch batteries. Get two more just like this and replace them.
Old Mar 24, 2003 | 10:51 AM
jasonrosen's Avatar
anyones battery die in there chirper
Old Mar 24, 2003 | 10:54 AM
cliffybabe's Avatar
CLK Coupe 200 Komp 53 Plate
mine hasn't got a chirper can i get one fitted?
Old Mar 24, 2003 | 01:15 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
I think he is referring to the Netherlands setting.
I would suggest you save by putting in your own batteries instead of the dealer. Just being cheap here.
For pics on key battery replacement RTFM.
