Light sensor -Visit workshop-
I also use Auxilary heater dayly (whole winter) so I think it will kill bad battery very short time if it is broken. I have set voltage down limit to aux. heater to 11V and it have ever stopped for that..
EDIT:
I made test tonight. I put battery charger to my car so we will see tomorrow is the battery problem..
Do you sensor still work with errors? Light and rain sensor both not working for me..
Error message did not return when the battery was replaced.
There have been other posts on this forum regarding this.
Let us know when you solve the problem. Good Luck.
if you have a weak bat even fully charged as soon as you crank the engine is sucks the power down
go get it load tested at MB my dealer tested mine for $21.00 and when it failed and i told him to replace it he waived the 21.00
Richard from england (guru) think problem in my star but have now tryed other version, so it was not it. My battery voltage today 12.2V before starting.
Once again: Battery.
Sir, just change the battery. Many of us have had to go through this methodically queer way of figuring out we need a new battery. We're trying to make it easy for you. CHANGE IT.
If I go to our dealer I think they:
1. Change light sensor (already changed)
2. Change Overhead control unit
3. Change Front SAM and so on..
I have my Own star but can't connection to Light sensor unit, overhead unit I can.
EDIT: They are very helpful in local part delaer and I would ask to give they new battery to try ..
! sorry had to add that in there, i have nothing productive to say other than goodluck!
