W203 Bad Radio Reception :(
Subscribe
Mar 24, 2010 | 09:53 PM
My radio reception has gone bad in my car the FM and AM stations have static now ((( I was cleaning the car and knocked the antenna of the back window, i glued it back on but my reception is bad now. However, I have been told by my mechanic that the antenna on the outside back window has nothing to do with the FM radio. I need help ppl :P
Reply 0
Mar 24, 2010 | 10:24 PM
Possibly the rear SAM?
From what I understand it is located under the headliner at the rear window. I have read here that MB wants to replace the glass and all as a repair, there are also post here indicating that it is available separately. Are the wireless functions on the Smart key still working from a distance? One of the symptoms is a greatly reduced range with the key as the antennae booster works for both the key functions & the radio reception.
Good luck.
Reply 0
Mar 24, 2010 | 10:33 PM
Good luck.
I have noticed no issues with using the key, I will try it from further away today, but havent noticed anything so far.
Reply 0
Mar 31, 2010 | 10:48 AM
you have a coupe or a 4 door? for a coupe the antenna is behind the top plastic piece under the hatch door.. its possible you got water in there and messed it up.. mine got water in there thanks to the tint i got.. but i repaired it.. didn't have to buy a new one
Reply 0
Apr 23, 2010 | 10:46 AM
Quote: you have a coupe or a 4 door? for a coupe the antenna is behind the top plastic piece under the hatch door.. its possible you got water in there and messed it up.. mine got water in there thanks to the tint i got.. but i repaired it.. didn't have to buy a new one
Totally forgot about this thread lol The key works better then ever, it gets crazy good reception, its just my radio stations, FM is ok - some static here and there AM - a lot of static I need a fix
and I have the sedan
Reply 0
Subscribe
Currently Active Users (1)
