CEL on again!!!!
called service dude , he says this is common, that the CEL is so sensitive, a sneeze can set it off.....
3 days later it went on again...the SA said it could be anything.... so i sent it in again today
on the other hand remember i had issues with the RF portion of the alarm module....first after my engine replacement ordeal it didnt work at all, only the IR...then the dealer did something with the RF amp and it worked but only at like 5 feet away max....so last week i mentioned it to them and they said there is nothing else wrong and that they could get it to work from like 50 ft away...and attributed it to possibly batteries..
they changed the battteries on the spare key fob and got it to work from distance....i tried with my main key and it worked, with out changing batteries...weird huh...also the AM radio started working again too...i assume my tints had some play in that, but just weird how when i asked them to look into that, ofcourse it starts to work fine thn.
hopefully this new CEL isnt gonna messup wht has become good...
Also, the sensors in the doors generally get very weak over time. Unfortunately, your situation isn't unique. Though usually it's the IR receivers that go bad, not the RF. (unless I have it backwards, which is entirely possible). I got the mods4cars module installed on my car, and can now open the doors/windows from much further away than before. That may be something to think about in the future, if your situation gets worse.
A guy came over to my parking lot at work and did it. I think it took him about an hour and a half all told, I think - had to take off the door sill, install, troubleshoot, etc. - it was his first time doing the install on a ccoupe, and the method that they show for how things should work when properly installed was not exactly correct for the coupe, probably due to the complication of the panorama sunroof.
and that the bad gasoline disrupted the new 02 sensor and some test they did showed something to be red and that the gas was probably bad.
ive used the same gas in all my cars, chevron supreme...ive never heard of this happening before
he said he can reset the cel, and wants me to drive it to empty and refill it and drive it and see if it happens again.....
the 6 days in between that i had gotten the car back from them and the light going on again, the car drove fine so i guess we will see
