Wider C7 wheel photos
Old Mar 28, 2003 | 04:47 PM
VoyagerDude's Avatar
2002 C230K, Silver, 6-speed, Evo, Roof, Leather, CD, Staggered C7 Wheels
Mark,
How can I tell if those spacers will fit or not?
Originally posted by MARK CUMMINS
The 203 401 24 02 is The Mercedes part number..
thanks For looking!
Please let us know if the 10/15/20mm spacers will fit
Old Mar 28, 2003 | 04:48 PM
I'm not making this up, honestly.
Originally posted by young
nope... none of those worked for me. i'm going to stop by and look thru the catalog and see if i can find them.
i think these wheels are on the slk's also.
Old Mar 28, 2003 | 05:00 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Originally posted by VoyagerDude
Mark,
The 10mm Spacer MIGHT Work...
Because with a Wider Rim/Tire The Gap will be Small..and if its lowered..its Tighter...It may Work
To See If it will work you will have to fit the spacer and the wheel WITH Longer Lug bolts..Then Be Very careful to see if it Rubs!
Good Luck
Old Mar 28, 2003 | 05:04 PM
Oh so I have to try it
Once I have the wheels on, I'll see how much more out they are.
Good Luck
Old Mar 28, 2003 | 06:26 PM
trench's Avatar
2002 C230 K
Originally posted by E320
Are they the same with 03' Sl500 7 spokes?I know they're 8.5 all around.
Those wheels are slightly different - although the spoke pattern is very similar, the SL500 wheels lack the raised "bumps" present on the C7/evo wheels.
Cheers, BT
Old Mar 28, 2003 | 09:54 PM
Lynn's Avatar
SL wheels have different offset and use 14mm bolts instead of the 12mm bolts used on C's.
Old Mar 29, 2003 | 12:51 AM
  #32
Iceman's C230's Avatar
09' BMW M3 E90
Nice wheels Voyager. We should have an Calgary MB meet so i can take a look at them this summer. Looks COOL.
Old Mar 29, 2003 | 01:03 AM
  #33
Thanks dude
We definitely should.
Old Apr 12, 2003 | 08:25 PM
  #34
I had my summer wheels/tires installed today.
Must say the wider rears with the Pilots look b i t c h i n '
Pictures to follow later, now it's raining ...
