Which speakers to tap for sub
However I found a power point presentation from before the w203 face lift that detailed all the changes. In it I found some interesting information.
It seems that the front speakers are designed to hit lower then the rear.
Now I dont know if this is simply due to them being larger, or if there is some sort of eq built into the speakers.
I need to hear from people that actually know the Mercedes audio20 system. Is there a built in EQ used on the low end stereo system? POssibly to protect the speakers?
They all put out 20hz. The fronts come through cleaner and louder, but that might just be because its a larger speaker. There does not seem to be any signal filtering at all by the audio 20.
I have found that the back right speaker might be blown, or there is a loose wire, I'll have to find out when I do my moleskin
