Which lug nuts (bolts) & center caps do I need?
As you can see I need centercaps, so if you guys can help with any info on those I would appreciate it too.
Thanks in advance!!!
If anyone knows contrary to the above, please let me know!
Edit: even though the rear wheels are a different offset, I believe they're drilled out to accomodate the same length lug bolts as the fronts.
Dealer sells a couple sytles of MB OEM centercaps for about $50 I believe.
C-Class (W201, W202, W203, S203, S210) - alloy wheel -
CLK-Class (208, 209) - alloy wheel -
M12x1.5 thread, R12 ball seat, 39.9mm shank, 17mm hex
But just to clarify,... incase someone later search and find this thread,.... Mercedes actually uses 3 different ball seat sizes: R12, R13 & R14 (Problem if you use newer W204 C class rims or SL rims with R13 ball seats). Different classes & generations & wheel types of Mercedes uses different size ball seats. All M12x1.5 thread are R12 ball seats. But the M14x1.5 thread lug bolts usually uses R13 ball seats,... but some classes like CL-Class (215), M-Class (from 07), Maybach & S-Class (140, 220) will use R13 ball seat only for steel wheels and use R14 ball seat only for alloy wheels.
R12 means Radius = 12mm
R13 means Radius = 13mm
R14 means Radius = 14mm
In addition, inside of rim has part number stamped on it,... and thus you can figure out what MB class/generation rim was originally for,... and thus ball seat size.
