Illuminated door sills...
The 2nd to last post is what i did to retrofit the standard EL door sills i bought from formymercedes.com to make it look more OEM-like.
As for these sticking on top of the original sills....I too thought it would look cheap, but after installing them, they look really good and very much OEM-like. Back many years ago, there was someone on here who would modify the "Mercedes-Benz" logo on the existing door sill to make it EL, but I think his company went under. Still, these from formymercedes are definitely high quality and worthy of your C-Class.
Cintoman
no choice unfortunately
1) the directions on there website are retarded - written by one of their customers who calls the provided strand of wiring a "transformer?" took me a minute to figure out wth he wanted me to wire the "LED logs" to that was a "transformer?"
2) Driver side goes on pretty much identical to the directions, good power, and turns on and off with the door ajar button thing...however now the driver side "one-touch" window feature won't work in the up direction. Apprently the constant power supply the instructions asked to tap into was the power supply to the window regulator. But why the up "one touch" feature ceases to work baffles me.
3) Couldn't get any power to the passenger side. It's identical to the driver side and all my taps are making contact with the wiring itself but still no power. Can't figure out for the life of me whats the dilio (plus i believe i blew a fuse in the process b/c now that window doesn't work at all and the light under the switch for the window on the passenger side is out) go figure.
4) anyone got any thoughts to this?
discernable, presuming you used these instructions, why it is/n't functioning
properly....as well as the inop statuses of your windows/lighting. are these
the instructions you used?
http://www.isynergyinc.net/mb/sill/
these are stick on that calls to tap into the power window power supply.
