C240 6 Speed HELP!!!
Old May 7, 2010 | 02:00 PM
taylortech's Avatar
2002 C240 6 Speed Standard
Exclamation C240 6 Speed HELP!!!
MBWORLD,
I have a 2002 C240 6Speed and everytime I change gears I can feel the whole car Jerk. As if My tranny is about to fall out. I am trying to find the Tranny Mount but all I see is AT tranny mounts. Are they both the same? Manual & Automatic Mounts? Do you think it could be anything else? It happens everytime I sink the Clutch and Re-engage it.
Old May 7, 2010 | 02:58 PM
MarcusF's Avatar
2002 CLK430
It could be motor mounts, the trans mount, flex discs, the pressure plate, or the clutch disk itself. The pressure plate, clutch disk, and throw out bearing are all replaced during a clutch job, so if one is bad, you'll replace everything anyway.
When did the problem start?
Old May 7, 2010 | 03:22 PM
taylortech's Avatar
Just started two weeks ago. But If it is the Trans Mount are all Trans Mount the Same? AT & MT Mounts? Because I can't find anything specific to a Manual Trans Mount.
Old May 8, 2010 | 02:50 AM
MarcusF's Avatar
2002 CLK430
If you post the transmission type, I'll tell you. 716.what, or a 717.what, or??? At $42 (dealer list), I'd just order one.
