Thinking about aftermarket rotors + pads
C320
I have the dreaded HUD 'Brake wear lining' message, so I was going to replace the pads in the next 2 weeks with some ceramic pads (akebono ? ), and I was also thinking about getting some newer rotors to supplement the ones on my 02 c320.
Tirerack has some rotors available, I just wanted to know what people's thoughts are on swapping rotors out from OEM to something else, if anyone could recommend a brand.
Thanks!
Thanks!
06 C230 SS 6spd
eventually you'll need to replace your rotors on your brakes, as long as they're up to OEM standards you should be ok. tirerack offers some good ones plus they have great customer service. akebono is the pads i'd go with for sure.
Might as well add SS lines if you're going to go through the trouble.
I'd definitely recommend Akebonos - I had no brake dust visible, which was great.
