w203 shaking
Old May 25, 2010 | 04:00 PM
dp20's Avatar
2002 mercedes benz c240
w203 shaking
hello all.. i'm a newbie here
i just put on some 19's on my w203 and lowered it with h&r springs...ride is good but when i start to hit 60-70mph on the freeway i feel sort of a shake...
what could be the problem...is it the alignment
and another question...
i want to get projector lights...any recommendation for a plug and play
im not thinking of getting HID's...and does anyone know if the lighting will be good
im debating on getting the clear oem headlights instead of the angel eyes
thanks for your help everyone
Old May 25, 2010 | 04:18 PM
jcnash's Avatar
2002 Mercedes Benz C230 Coupe
Do you feel the shake in the steering wheel or near your feet? If its the steering wheel, check the front wheel balancing. If its near your feet, check the rear wheel balancing. Maybe you have a bump/ding on the rims?
Do you have a sedan or a coupe? If you have a sedan, getting headlights should be easy. Good luck if you have a coupe!
Old May 25, 2010 | 04:22 PM
timmynabenz's Avatar
2006 C230 SS, 2006 S500, 2008 CLS550 Lorinser
do you have spacers? if so i could just be the spacers
for the lights i would get OEm clear or Depos
Old May 25, 2010 | 04:26 PM
skittles's Avatar
Moped
if the shaking only at certain speeds try running faster till you dont feel it. are you using wheel spacers? generic or hub centric?
possible causes: wheel/s unbalanced, alignment, tires not round, bent wheel/s, and generic wheel spacers will always give you a wiggle.
if your not gonna use HID OEM clear headlights should be ok. no use for projectors really if you use halogens.
Old May 25, 2010 | 04:54 PM
dp20's Avatar
thanks everyone
im on the way to get my wheels balanced
i have spacers in the front, but not the rear
as far as the lights are concerned, can i get the depo ones and still use the stock lighting...will it look ok?
Old May 25, 2010 | 05:06 PM
skittles's Avatar
Moped
Originally Posted by dp20
thanks everyone
get hub centric spacers first. bimmec or H&R.
Old May 26, 2010 | 12:40 AM
phister's Avatar
06 C230 SS 6spd
yeah sounds like you need an alignment and some hub centric spacers.
Old May 26, 2010 | 05:57 AM
Glyn M Ruck's Avatar
Super Moderator
+1
Old May 26, 2010 | 12:09 PM
dp20's Avatar
thanks for the help
went and got the car aligned and balanced and the ride feels way better, but still a slight vibration...maybe their isnt such a thing a perfect ride anymore
we left the spacer on the front wheels and he quoted the hub rings for the rims @ $45 a wheel
is the hub ring necessary? will it damage anything if i dont get em...
the alignment fixed the rear scraping too
so again, thanks everyone for the advice
Old May 26, 2010 | 12:14 PM
ITS THE SPACERS. god damn lol
even witht he best psacers there will always be vibration, thats why i hate them!. lol
Old May 26, 2010 | 12:16 PM
skittles's Avatar
Moped
+1 to timmy.
best thing is to get perfect fitment wheels.
Old May 26, 2010 | 12:22 PM
dp20's Avatar
umm...
dont mean to ask another question but...
do i just take off the spacers and thats it or should i take them off AND get the hub rings?
Old May 26, 2010 | 12:24 PM
umm...
do you need the spacers or just have them on for looks? I'm guessing you need them to clear your calipers if they're on the fronts, because most of the time if its just for looks its on F/R or just rear. If so, you NEED spacers.
Like Patrick said the best thing is jsut wheels that are proper fitment, but if you really like your wheels, you kindof get used to the vibration
Old May 26, 2010 | 12:38 PM
skittles's Avatar
Moped
again +1. in addition you need the spacers for the caliper or strut clearance.
Old May 26, 2010 | 08:37 PM
Super Moderator
Bugger the rings. You need decent hubcentric spacers.
