help locating tranny part
Old May 28, 2010 | 09:48 PM
kastnna's Avatar
2006 c280
Anyone know where to locate the TCU on an '06 C280 is located? Everybody else seems to have one located on the back of the metal plate under the passenger side carpeting in the footwell. I don't.
Any ideas?
Old May 29, 2010 | 10:50 AM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
Any ideas?
Welcome to the forum.
It is inside the transmission, integrated into the valve body on your car, since you have the 722.9/7G transmission. What are you trying to accomplish?
Old May 29, 2010 | 11:09 AM
kastnna's Avatar
2006 c280
Oh thanks.
The transmission is a little jerky and, most annoyingly, it often seems to be in too high a gear. It'll be in 4th when I'm trying to merge into traffic and need the power of third. More than once, I've accidentally cut someone off because of the lag in this tranny.
I've lurked the forums for a while, and some claim it's just part of this 7G tranny - that the car "races" to the high gears to increase fuel efficiency. But I had also read that a dirty MAF could cause the lag, new firmware seems to help some, and oil wicking up into the TCU can cause problems.
I've addressed everything accept that last issue. Seems that it isn't applicable for my car.
One new, slightly related, question do the w203's have a "93 octane" setting? Where I live, 91 is rare, so I always run 93. Am I missing out on some of the power/efficiency of 93?
thanks
Old May 30, 2010 | 10:36 AM
jrsmith_68's Avatar
Veteran: Army
2007 C350 2015 ML400 1968 Ford Mustang
Oh thanks.
thanks
How does it behave in S (sport) mode vs. the C (comfort) mode? I notice a big difference in mine as it will hang in a gear longer. Also this mode starts in 1st gear vs. 2nd.
