best match to stock color on wheels
2005 c230 s/c
i want to paint my wheels on my c230. looking for the best match.
i knw you cant get the paint code for the stock wheels.![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
the wheels are a gunmetal/dark gray metl. the wheels look good but i want a stock look.
thanks
thanks
'05 C230
Can you post pics of a photoshopped or even an actual painted gunmetal rims please? How are you going to paint your wheels and also, how much will the pros do it? Thanks!
2005 c230 s/c
'05 C230
The stock rims should be painted a color called Hyper-Silver, but that shade varies from supplier to supplier. Not easy to find a paint code for this, but it has also been referred to as:
Glasurit TitanSilber Met - 9765, on other MB forums.
There is also this info which came from a MB discussion forum in the UK-
The paint codes for the colors of these wheels are:
Primer 76-71
extra fine silver 61-090
sparkling class 66-009
These came on a set of color cards from a Mercedes dealer
Not sure if that helps or adds to the confusion. I have seen a number of silver brake caliper paints that very closely match the Hyper-silver color, or you can contact a MB dealership and see if they have any better info.
Good luck.
Primer 76-71
Good luck.
2005 c230 s/c
Wurth makes a match for the hyper silver used by the German manufacturers. Available in a spray can. They make a clear coat to go along with it, be sure to use that also.
