hid or no?
What are the low beam bulbs in my car? D2R?
They have 2 setting i think, daylight and nightime...would that effect anything if i want to put hid's.
Anyways, I'm really new to this, please help.
On my previous C230SS, cheap ebay kit with capacitors lasted almost 2 yrs before one of the ballast went dead. So I bought the same kit, replaced the ballast and still had extra parts for spare. Back then I paid $90 now it costs $37 for the same kit from same seller.
Another option would be to buy Mtec kit, just plug and play but I'm cheap so I chose capacitor method. I did this to my 06 ML350 and it's been great!
My car has clears, whereas my old CLK had the foggies.
projectors are a no go for sure: too expensive.
I'm getting pretty bored with the look of my car's headlights lately, so wanted to try hids. So should I do an hid conversion on frosty headlights?
this produces an insane of amount of glare which blinds oncoming traffic and creates hot spots on the ground.
But each car is different in how it reflects so it might not end up being as bad. If you do decide to do it i would recommend you get a D2R bulb and buy the adapters to fit it into an h7 housing. the d2r is made for a reflector type housing and will reduce the glare above the cutoff line
But do not kid yourself the MB 05+ headlights where not at all, if they where, then why would MB have wasted the time to made a whole new housing for the HID option instead of simply shoving a ballast and bulb on board the housing they already spent money to make?
Because the reflectors suck, they cant focus 4800 lumens of light properly. Not because I did it wrong, and heres a hat tip to your blindness of the fact that you prob think (if you have a HID kit in your reflectors) that you arent throwing glare every where on the road.
There you go. Is there "some" glare? Probably, yes. Is it "all over the place"? Clearly, no. It's WELL focused.
Then by the time I'm done reading, I'm completely discouraged...
Yet, in the back of my head resides a possible alternative... just install the Sylvania H7SU SilverStar Ultra in the stock HAL housing and be done with it.
This is how it was on our '06 C230SS:
'06 ML350(projectors):
'91 Z(projectors-amazing for 20 yr old car):
All had/have same $37 ebay kit.
4800 lumens? No. They can say whatever the want but the kit is not pumping 4800 lumens. We all know the reflector housing wasn't MADE for HID. This is obvious. Let me get you a photo of my HID beam pattern:
It's your opinion that an older Acura with a HID reflector is crap? Based on what? I can assure you, having owned a 2002 Acura TL with factory HID, it was not crap. However, it was also no better than my HID kit in the Benz.
Please point me to where I was arguing against projectors? Reflectors are perfectly capable of handling HID. Projectors handle it better with neater packaging and easier Bi-Xenon implementation.
What?
Like I said, you did it wrong - probably by allowing inept dealer techs to install it. I ran a HID kit in my reflectors successfully for over a year. As you can see from my photograph, I enjoyed a very-near stock beam pattern. I have since reverted back to halogens due to heat issues with the 55w HIDs. I recommend OEM Bi-X, but often that is price prohibitive. As a side note, I've forgotten more about cars than you probably know. I don't need your omg-run-on-sentence-fail lecture.
You photo shows one big giant blob of light, no cut off no even scattering of light, it doesnt smoothly taper off like projectors do, and being a camera phone pic, it looks like it didnt quite catch all the light.
Since your such an expert ill post pictures of my headlight pattern and you tell me what I did so WRONG, I properly aimed them and they are a 55W 6000K DDM kit. I still stand by the HIDs in our OEM housing look like crap, the photo you posted any my personal experience with it confirms that.
And I didnt even have to insult you 2 times to say that.
You're entitled to your opinions, and your experience may vary. But just because it sucks for YOU doesn't mean everyone will have the same experience. I also did not need my xenon set to present or any sort of error eliminators to make my HID work fine unlike most on this board.
