Another COMAND question (yes, I STFF)!
Old 06-11-2010, 01:15 PM
kastnna's Avatar
2006 c280
First off, I want to say thanks for all the awesome knowledge you guys have bestowed upon me. So far the tutorial on locking down the shifter boot bezel and the InstallUniv tutorial on replacing the grab handle have gone off perfectly. I've also taken to cleaning my own MAF and replacing my own air intake filters regularly. And I'm most pleased with the AUX input that is now run to my armrest (and a 12v splice) to both run and charge my ipod. I even managed to install my Garmin Nuvi cable inside the dash. So thank you all very much.
Currently, I'm working on three projects. 1)installing the digital climate control interface (just waiting on the parts); 2) replacing my swaybars (haven't tackled yet); and 3) upgrading to a COMAND.
My question is about the COMAND. I've searched relentlessly, but every answer I find is refuted by someone else. And all this pre-/post-facelift stuff means that many posts don't (seem to) apply to me.
In a nutshell, I'm looking for the badest-assed COMAND system that can be put into my '06 C280? Obvisouly, I don't want to go to the dealer and shell out $2500, but I would like US NAV, MP3 on harddrive, DVD, etc.... I've got a 6 disc changer, if that matters (I think it does). More than anything, I would kill for someone to equate COMAND models with part numbers. In searching car-parts.com and EPC-Startek I've found A2038705489, A203871189, A2032989, A2038704189, etc, etc.... I don't know which one I should be looking for.
If someone can tell me which part number to be searching for, I'd be eternally grateful.
Old 06-11-2010, 01:30 PM
BF_JC230's Avatar
2005 w203 C230
Contact Steve and MBENZNL...I am thinking the best one you can get out of a CLC IF applicable (European V. American)...or a G Wagon...
Good luck!
Old 06-11-2010, 01:39 PM
kastnna's Avatar
2006 c280
Thanks.
I did contact Steve. Quoted $1400, which from what I've read, is not unreasonable. And everybody here says Steve is a stand-up guy.
But I also hav a handful of clients in the salvage, junkyard, and autobody biz. I bet I can pick one up from them for $500 if I can tell them EXACTLY what I'm looking for.
Like I said, it's equating the part numbers to the models that is stumping me.
Old 06-11-2010, 03:12 PM
e1000's Avatar
a quarter mile at a time
I was secretly thinking about doing the same thing before I decided to sell my car. The big question I came across is the compatibility of the COMMAND units out of the Sprinter Vans.
http://cgi.ebay.com/ebaymotors/Sprin...fAudioQ5fVideo
As far as I can tell, these are the right shape and have all of the up to date features. What I don't know is if they'd work in a w203.
Mercupgrades is also a great website for information on this type of upgrade.
Good luck.
Old 06-12-2010, 04:21 AM
OverDrive's Avatar
Volvo
Ebay is a good way to get one (Range $400-800) You want an Mercedes 2006+ MCS II Comand System, It needs to be 2006+ to support MP3, You can get one from an 05 but it doesn't support mp3's,
The CLK MCS II is a tad smaller than the W203 (Still fits but theres a small gap)
Take a look at my DIY listed below on the comand system, Theres some threads i made in the C32/C55 section about the comand system
Old 06-13-2010, 10:22 AM
kastnna's Avatar
2006 c280
Thanks for the advice thus far.
Let's try a different approach: Does anyone know the part number for a US Comand NTG2.5?
Mercupgrades.com, unfortunately, is provided almost exclusively for EURO models. I don't want the headaches associated with that route.
Old 06-13-2010, 05:17 PM
nickgailloux's Avatar
2005 Mercedes C230 Sport Sedan (W203)
The only C-Class US NTG 2.5's are for the W204... and they use a totally different shape and mounting system as the center console was redesigned.
From what I know, these would be your options for comand in your car:
1) 2005 MSCII C-class comand (no MP3 as mentioned above). You will have standard options. Easy to find used and cheap.
2) 2006 or 2007 MSCII C-class comand (Gain MP3 playback) Somewhat easy to find used.
3) 2006+ MCSII G-class comand (Gain MP3 playback and backup camera input) Very hard to find used.
4) 2008 CLC Comand NTG 2.5 APS (Euro) (Gain bluetooth phone, unsure about backup camera, and I have not heard if anyone has US nav maps working on it) Hard to find.
As mentioned, the CLK comands have a slightly different shape and it wont look right. I dont believe the sprinter, viano, A or B class comands will fit at all. And obviously the E, S, ML etc comands do not fit.
As for part numbers, there are a LOT of different part numbers for each comand/car. The comand is continually revised and as such even the factory comand for your car could be one of many part numbers. In general I think compatibility is pretty high so its worth taking a chance here or there. Pretty much any 2005-2007 MCSII C-Class will work in your car.
Old 06-14-2010, 09:17 AM
kastnna's Avatar
2006 c280
Thanks Nick. I'm more confused than ever now, but your post was exceptionally thorough.
I thought a 2.5 could be retrofitted into a w203 becuase of this post (https://mbworld.org/forums/c-class-w...ntg-2-5-a.html). I realize this was a pre-facelifted w203, but it is a C class and an NTG2.5, nonetheless.
Again, thanks for the breakdown provided above.
Old 06-15-2010, 05:31 PM
He did option 4 from my post, CLC comand from a european car. This works for him nicely, since he lives in Europe (as far as I can tell from his posts). You may or may not be able to put North American maps on it, but until someone wants to drop the $ and try it out, we don't know.
Old 06-15-2010, 06:12 PM
Super Moderator
johnand's Avatar
2007 C230SS; 2014 ML350 BT
Nick, I have been researching this, and I don't have a 100% legitimate source, but it appears the Euro and US 2.5 NTG Commands are the same just country coded via STAR, and obviously have different maps. I still have a lot of WIS documents to read through to see if that is correct. I am really close to buying a CLC/G-Class NTG 2.5 Command and see if I can code it via STAR to work in my 07. They are available on Ebay, but still $1600 US.
Old 06-15-2010, 06:22 PM
W203E35's Avatar
2006 C350 Sport 6MT
I remember a member had the EURO COMAND. He got the Euro DVD and US DVD and he merged the maps and data files together and he got the US maps to work on the Euro COMAND. Also I know with STAR you can change the frequencies on Audio 20 so i'm sure you can do this to the COMAND as well.
Old 06-16-2010, 02:10 PM
kastnna's Avatar
2006 c280
But still no MP3 on the Euro, or yes? Fact is, I have a Garmin Nuvi 780, and CDC, and an ipod aux-in, so unless I can add BT, Mp3, DVD, SD card, etc... I can't justify the price.
Karo, I too saw the "hybrid DVD" thread and I'm pretty sure he got it working.
My only concerns with the euro radio were the MP3 playability and the radio station differences. If those can be worked around, I might be willing to try "option 4".
Old 06-16-2010, 02:52 PM
e1000's Avatar
I believe all NTG 2.5 units have MP3 capability (if it dosen't you can do it through a MP3 compatible CDC), aux-in, DVD, built in bluetooth, and SD-Card.
Old 06-16-2010, 04:02 PM
Super Moderator
johnand's Avatar
Eric is right all NTG 2.5 units are MP3 capable. And, if my source is correct about the Euro and US units being the same, other than coding, the radio frequency difference won't be an issue.
Old 06-16-2010, 04:05 PM
Super Moderator
johnand's Avatar
I don't think the "hybrid" disc in necessary on NTG 2.5 units. Just country coding then loading of the appropriate country map.
Didn't know you could change the tuner frequency on Audio 20. If that is the case, then my source may be correct that the frequency can changed based on unit county coding.
Old 06-16-2010, 05:02 PM
kastnna's Avatar
2006 c280
Okay... So sell old audio-20, sell CDC, sell ipod, sell garmin, divorce wife, sell wedding ring... then maybe afford NTG2.5!
Old 06-16-2010, 06:44 PM
Super Moderator
samaritrey's Avatar
THE C350
divorce wife? no you buy this on joint credit card then divorce her.
Old 06-17-2010, 08:24 AM
Super Moderator
johnand's Avatar
Old 06-17-2010, 08:42 AM
kastnna's Avatar
2006 c280
Well played sir, well played.
Old 06-18-2010, 12:30 AM
that was me... lol
Old 06-18-2010, 12:32 AM
Wow, this is awesome news... if you're correct, then I think I might want to go that route. I'm definately interested in this. Keep us updated on your progress.
Old 06-18-2010, 12:01 PM
OverDrive's Avatar
Volvo
Enjoy! http://mbdoctor.com/item-C-W203-COMMAND-APS-19.html I used them for parts when i was converting my car to MOST
Old 01-26-2014, 08:58 PM
Arab_Homie's Avatar
C55 / S550 / Lexus IS300 (sold) / C63 (Sold) / SL500 (Sold) / Lambo Gallardo (RIP)
Anyone else on this? I have a C55 and an NTG 2.5 from a G wagon. What are my options to get it to work?
Old 01-27-2014, 03:15 PM
drho2004's Avatar
2005 C230 SS
interesting thread. i myself went for a MCII from a wrecked 2006 c-class. got it cheap for $200 then sold my Audio 20 on ebay for $200
i did research and noticed that there are alot of different models. went for this because it was cheap and it was plug and play. i would have gone with aftermarket but i have the H/K Amp and from what i read they dont play nice.
Old 01-30-2014, 04:40 PM
Stuka Bomber's Avatar
2007 c280
^where did you get it for $200?
Quick Reply: Another COMAND question (yes, I STFF)!
