RennTech Shocks/Struts ebay
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Armenians don't know about Kleemann or Renntech. They only know Brabus, AMG and Lorinser ![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
Have you guys ever seen the Brabus Lorinser?? One of the local guys here in Burbank has one. I believe Brabus and Lorinser joined together to make this 1 of 1 S-Class
Edit:
It's gold color too.
Also there is an S600 but it's customized to an S320 body for weight reduction. A lot of crazy custom cars in Glendale
Edit:
Super Moderator
Edit:
Edit:
lots of crazy custom cars in Glendale. last time I was in Glendale, I saw an "S55 AMG" with no visible exhaust on it! or my favorite, was a "C55 AMG" but with a front and rear C230 conversion
#32
looks good wish i woulda jumped on this at them time...got 65k on my 05 c230k now but suspension is still going strong so hard to justify any expense on it...especially when im trying to at a cf diffuser and 2nd exhaust pipe.
#33
1 Post
'03 C320 Sedan, '04 SAAB 9-3 Cabrio
I am having the Renntech kit (as discussed above) installed today. along with the C32 springs. Mechanic just called me to say the shocks are an inch shorter than stock and the car would be "significantly" lower. Anyone know about this? Shouldn't the shocks be at standard height? Is this an issue? Thanks if anyone knows.
#34
2003 c240
Did anyone else put the shocks on themselves? I had some issues properly tightening the tops. I had to add a washer so that the rubber would expand properly to tighten it down. Anyone else have this issue?
#35
1 Post
hmm this might be true. I installed the rears so far and also put #4 pads on and the car sits at nearly the same height with the #2 pad in. So it might have lowered it.
#37
1 Post
My mechanic said he could not get the spring compressed enough to fit on the struts. The strut piston only comes out a few inches. It was not reaching to the mounting point. Any ideas anyone?
Also, he got the rears done with the C32 springs. Lower by about a half-inch.
#39
Super Moderator
New dampers have no effect on ride height unless the gas pressurization in the old pieces had equalized. Most available MacPherson strut replacements have virtually identical steering knuckle-to-lower spring perch dimensions which, exclusive of the springs’ load height, ultimately establish front ride height.
The “shorter” your technician likely referred to was their length at full extension. That is to say when the suspension is fully unloaded, be it from high speed whoops, raised via a floor jack, or traversing off-camber driveways and drainage culverts. Damper manufacturers do so to cover their tails since they’ve no control over whose springs will be fitted. It’s seldom an issue in the front, but shorter aftermarket springs can rattle in the rear perches at full droop owing to excessive travel.
edit: your mechanic must clamp those buggers down sufficiently in order to get the strut bushing’s nut home..
![](http://i209.photobucket.com/albums/bb196/splintersAMG/SpringCompressor.jpg)
#40
1 Post
Splinter, thanks a lot for the explanation. The piston on the strut protrudes about 4 or 5 inches. It won't come out any more than that, unless there is a trick to unlock it so to speak. He only was able to install the rears, left the fronts at stock. Something about not being able to compress the spring enough and/or the length of the strut being less than the distance to the mouinting points ( I think). Could not extend it enough to mount it to the upper mount. That was the problem he had.
