Engine Check ?? help
Old Jun 18, 2010 | 10:58 AM
Kurupt's Avatar
02 c230k coupe
So today i was driving and i stopped at a red light. When i started going on green my car started shaking and felt like it was about to turn off on me, like when the rpm drops down low in higher gears and it feels like its about to turn off. So then i stopped at a red light again and my car was still shaking, so the check engine light came on. I got to my house turned off my car checked the engine, there was no smoke or anything coming out of the bay, it was all clear. When i turn it on now, there is no shaking and everything feels normal except the check engine light is still on ....
Anyone have a clue to what is going on ? Is there anyway i can find out what the problem is ...
Old Jun 18, 2010 | 11:20 AM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
It is really hard to diagnose without the appropriate scanning of the diagnostic codes. Please buy or borrow a code scanner and post the codes here. You can also go to most autoparts stores and they will scan your codes for free.
There are quite a few posts like yours that end up being MAF sensor related.
Old Jun 18, 2010 | 04:54 PM
lancemb's Avatar
03 c240
something sort of like this happened to me as well. found out later that it was a faulty transmission conductor plate. here bro http://repairpal.com/mercedes-benz-c...ommon_problems
Old Jun 18, 2010 | 05:59 PM
Glyn M Ruck's Avatar
Super Moderator
As John says - scan for Codes. If one reboot solved the problem it might just be a brain fart of the ECU or you might have triggered limp mode. Continue driving & the light might go out.
Let us have those codes. Oh! and clean your MAF if not done recently.
Old Jun 18, 2010 | 09:18 PM
Kurupt's Avatar
02 c230k coupe
alright thanks for the input
ill get the codes and post them tomorrow
Old Jun 19, 2010 | 11:56 AM
Kurupt's Avatar
02 c230k coupe
So i got it checked out today
It was a cylinder 1 misfire, code p0301 i think.
The check engine light went off, but i have a friend and he said he can fix it once the light comes on again.
Old Jun 19, 2010 | 12:46 PM
Super Moderator
Plug, wire or coil on plug. See if it comes back.
Old Jun 20, 2010 | 09:40 PM
Kurupt's Avatar
02 c230k coupe
So my check engine light turned off and the car is running fine.
I took the car to my friend and he took a look at it and also said everything was fine but he told me to buy a bottle of sea foam to clear the igniation and everything so....
why do you think it went away ??
Old Jun 21, 2010 | 11:31 AM
Javvy's Avatar
13 Jeep JKU Sahara w/4" lift Kit & the works,2015 Toyota Sienna XLE,2013 Hyundai Sonata Hybrid
amazing stuff that sea foam thingy.........I have used and can concor.........cleans the **** out...but make sure that you are in an isolated location as the car will bellow white smoke as if it is a steam engine..............but sure does clean the entire ignition/intake/injectros/plugs............etc etc......BTW how many miles on your ride???
Old Jun 21, 2010 | 01:53 PM
Kurupt's Avatar
02 c230k coupe
around 78k miles.
So its safe to use the sea foam on a mb engine ?
Old Jun 21, 2010 | 01:57 PM
samaritrey's Avatar
Super Moderator
THE C350
Originally Posted by Kurupt
around 78k miles.
No
Old Jun 21, 2010 | 03:27 PM
Kurupt's Avatar
02 c230k coupe
what you mean no ?
Old Jun 21, 2010 | 03:51 PM
Javvy's Avatar
I am on 45k miles when the time comes say around 75k-90k miles I will sea foam the car..........just google Sea Foam and read about it.
