Oil change
Rating: Thread Rating: 2 votes, 5.00 average.
Old 07-08-2010, 01:53 PM
solekeeper's Avatar
A V8
Oil change
Hey guys, I did search before this so please dont flame.. I did get a thread that was helpful too. But I'am however confused, i ran into a thread about the c230 oil change, but it seems to be for the new 08+ models.
My sister has an 07 c230, and I was going to do the oil on it.
What type of oil, and how many quarts?
And also, I'am doing it the basic way (from bottom) will the bolt need to be replaced? Thanks guys!
Old 07-08-2010, 02:06 PM
Super Moderator
Glyn M Ruck's Avatar
The 07 C230 has the 2.5 litre M272 engine. Requires about 8.5 quarts with filter change - this is in the owners manual but never quiet ties up as you can't get every drop of old oil out of the engine.
You require oil meeting Benz spec 229.5 - Mobil 1 Euro formulation 0W-40 meets this spec. Make sure you use a "fleece" Mann + Hummel oil filter - available in Mann packaging, Genuine Benz packaging & a few other rebrands like Bosch & K&N
The drain plug is microencapsulated with sealant. If you want to reuse it - use one of the non hardening sealants from Locktite or similar to make sure it does not weep.
Good luck!
Old 07-08-2010, 02:15 PM
Super Moderator
This is what a fleece filter looks like - on no account use cheap paper filters.
Old 07-08-2010, 03:38 PM
jcnash's Avatar
2002 Mercedes Benz C230 Coupe
Does this apply to the '02 coupes as well? I used a paper filter during my last oil change (not knowing that it wasnt the fleece filter!!)
Old 07-08-2010, 06:26 PM
solekeeper's Avatar
A V8
glyn, thank you so much for your informative post!
Question, is there a washer that is in between the bolt and crankcase?
Old 07-08-2010, 08:19 PM
Super Moderator
samaritrey's Avatar
THE C350
yes there is a washer that needs to be replaced if you remove the drain plug.
Old 07-08-2010, 09:30 PM
solekeeper's Avatar
A V8
Thanks, anyone know the part number?
Old 07-08-2010, 11:33 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
If you've read through the prior threads, why are you draining the oil from the bottom?
Old 07-09-2010, 05:56 AM
Super Moderator
If you have a M111 engine there was never a fleece filter available. If you have an M271 engine then there is no longer a fleece filter available in the US. Don't know about Canada. Used to be mandatory for 13,000 mile, 20,000Km oil drains & IMHO still should be.
For ROW readers/members a fleece filter is still available for M271 & all larger petrol engines
Old 07-09-2010, 06:14 AM
Super Moderator
Part number is 007603-014106
See: Drain plug seal ring - engine - cost 22 cents
http://www.rmeuropean.com/mercedes-parts.aspx#Group
Old 07-09-2010, 06:20 AM
jagass's Avatar
pick up
I have a scheduled oil change by September, so I need to know about this things too. lol
Old 07-09-2010, 10:24 AM
jcnash's Avatar
Thanks Glyn.
I have the M111 so guess I dont have to worry about it.
Old 07-09-2010, 12:19 PM
Taiwanese's Avatar
2003 C230
Glyn,
I enjoy reading your posts. 0W-40 is the oil to use for MB. But in southern California weather, is it necessary to must use 0W-40?
Old 07-09-2010, 12:57 PM
Super Moderator
You must use products meeting 229.5 & thus passing the MB HTHS (High Temperature High Shear) test.
I use my old company's 5W-40 229.5 product in my car.
See my Definitive Oil Thread.
Old 07-09-2010, 01:15 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
+1 to glyn comments. He's the expert when it comes to oil on this forum.
Old 07-09-2010, 06:43 PM
solekeeper's Avatar
A V8
Thanks again glyn for the pn.
So I'll need 8.5 quarts of 0-40, and the drain washer.
Tommy, as far as I understand, both ways are ok (bottom or other way)
Glyn, since your the expert it is ok to drain from the bottom right?
Old 07-09-2010, 08:35 PM
Super Moderator
Fine either way - just easier to suck out but then you need a Mityvac or similar
Old 07-10-2010, 05:39 AM
tommy's Avatar
Yes, only Glyn has done oil changes.
It's your time, but it would be much better spent ponying up to a topsider and letting it do the work for you, instead of jacking up the car, removing belly pans, removing the drain plug, getting a new ring, throwing all of your now-soiled clothes in the wash, and doing the reverse of all of the above.
Old 07-10-2010, 08:44 AM
Super Moderator
Old 07-10-2010, 04:03 PM
jcnash's Avatar
LOL and +1
Old 07-11-2010, 08:01 PM
Popo's Avatar
2007 GL450 2005 C55 2002 C32 sold 2001 ML320 sold
+1 on the Topsider or MityVac. Did mine last night on a c55, 22 minutes for oil and filter, almost no mess. Replacing the filter got my hands a bit oily :-).
Old 07-12-2010, 05:06 PM
vovanich123's Avatar
2006 c230 6spd
is MityVac 7201 going to work fine or is there any specific one to fit the job better, and are there any instructions in how to use it? thanks
Old 07-12-2010, 05:48 PM
e1000's Avatar
a quarter mile at a time
lets be clear, not just 0w-40, but Mobil1 0w-40 European Formula. Not all 0w-40 are 229.5 approved, nor are all Mobil1 oils 229.5.
Old 07-12-2010, 06:02 PM
Taiwanese's Avatar
2003 C230
They are all about the same just different capacity.
How to use:
insert extractor tube through dipstick tube all the way to the bottom of oil pan
pump the handle a few times
what oil being extracted
a few more pumps if flow rate slows down
pull out extractor tube after you can't get anymore oil out
put in new filter
add oil
check oil level is correct
Old 12-08-2011, 01:54 AM
FlipSRT4's Avatar
06 c230 Sport, 03 SRT-4 Mopar Stage 3
Good luck!
Would I still need to do this ^^ if I buy this "Part number is 007603-014106
http://www.rmeuropean.com/mercedes-parts.aspx#Group "
Im trying to do an oil change on my 06 c230 sport and I have searched but have not found any real specific how to's(unless i just fail at searching lol) Besides making sure i get the euro mobil 1 ow-40 mb approval 229.5 oil and fleece filter, is there anything else i should know like having a special MB tool of any sort? Sorry if this has been asked, i do my best to find out first.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: Oil change
