View Poll Results: do you like the dual temp climate system?
yes, very useful.
26
61.90%
no, i do not really use it.
9
21.43%
yes, but i have a c230k and wish it was digital
6
14.29%
no opinion
1
2.38%
Voters: 42. You may not vote on this poll
dual-zone climate control? like/dislike?
what do you think about the dual-temp climate system? i sort of like it except when i am by myself and i have to set both dials. does the digital one have like a 'master' temp control?
2001 MB CLK55
OK, so mine is in a CLK55, not a C class, but I find the dual zones to be an absolute necessity when I'm not alone in the car (nobody else seems to like it as chilly as me - typically set mine at 66-68F).
Enjoy!
Enjoy!
I've never noticed a difference even when the temperature dials are at opposite ends. Sure, the air blows cold on one side, warm on the other, but once it gets in the cabin, it mixes and doesn't really change things. I think it's one of those features that's good in theory, but not really practical.
I like it. I think most married guys like it, because wimmen always like to have the car 20 degrees hotter than it should be. At least with dual zones, you can fight back a little.
Actually, I like the system on my '86 535 better, though. Besides being a lot simpler, it works better. The way they have it set up is so that only cool air can blow through the center dash vents. Hot air comes through the upper windshield vents and the lower footwell vents only.
They do this because its not good to ever have warm air blowing directly on you. Makes you groggy.
So, when its really cold, you just push the lever to shut off the center vents.
But when one passenger gets to hot, he can just open the center vents and point the cool air at his face! It also is refreshing to sometimes point cool air at your face when you are driving in a heated car.
My biggest complaint about the MB system is that I can't figure out how to get just plain, unmodified outside air flowing through the dash vents. No matter what I do, the air seems processed, usually somewhat humid.
1 Post
C230K Coupe/Orion/C4/C5/CD/AMG Spoiler/V60/TeleAid, 2 MGB's
I'd like it a lot better if it had the electronic display as I've seen in some C Class brochure's. My girlfriend likes it, and LOVES the heated seats.
2002 Lexus IS300 5-speed
I can only use it in the summer for air conditioning. I cannot use the heater because it blows hot air to my leg and makes my shin and calves extremely dry and itch. and I cannot find to shut the airflow to the floor in auto mode.
I was a little skeptical at first, but since my wife likes it a lot warmer than I do (Socal is right on the money), I have found that it works quite well. If she sets her side to 72, and I set mine to 68, we are both comfortable. In her car, I sometimes end up sweating my butt off. I'm interested to see how it works in the heat of the summer though.
White C230 Coupe, Leather, Evolution, Panorama, Heated seats, Bose, Factory Alarm
Love the climate control....
Never ever had to fool around with adjusting the temp or the Fan speed again..... I set both sides to the same temp.
ALL the girls LOVE the heated seats...
2002 C240 6-spd (ret)
Location: Houston,TX-moving to The Woodlands,TX SOON!!!
Toyota Tacoma & Lexus IS250
the entire climate control system seems VERY slow to react to my inputs which is weird.
Yes the dual system (digital here) is nice to have, but I think the overall system could function better.
I had an Infiniti I30 (not dual) that if it was 30°F outside and I set the system on 80° - the fan wouldn't even start until it could produce warm air....then it would blast on HIGH. I'm assuming that's how the MB system is SUPPOSED to work, but it doesn't (not mine anyway).
I know there's separate AUTO mode for the temps and fan speed...but the AUTO fan speed doesn't work too well in my opinion.
anybody had better luck ?
the 80° setting was MY WIFE'S SELECTION...
if it was set on 72 it would do the same thing until the temp inside the car gets close to 72...
I've never seen my C320 AUTO fan speed EVER move or change - and IT SHOULD -- and not take 10 mins to change.
//// BUT I LIKE THE DUAL SYSTEM !! //// Just think it could function a little better
1 Post
2007 GL450 2010 GL550 2020 Sprinter 4x4
I personally think it is a gimmick, one that my wife likes. She sets hers in the red all the time. What they should do is combine the ventilated seats with dual zone. That way the heating and cooling effects would be localized, somewhat.
I don't know
I'd prefer a retrofit of my 12-year-old crx's hvac system. I like the 4-speed fan with different settings.
My preferred setting is to have no heat with a little cool air blowing, which is impossible on this "more advanced" system. Of course, I'm single, so I don't really have to care much about not offending the better half.
I'd really like an override setting to cancel out the temp part of the system, but I'm assuming that now that we're temp and zone based, the easy days are behind us.
I am very pleased with the way this works, and the car seems to heat up very quickly on those blistering cold 40 degree mornings. Brrrrrrrr. :p
Originally posted by BigBadDad
2 words: Wear pants
2 words: Wear pants
In my case, it's not making any difference, pants or shorts.
Only thing to do keep putting lotion on.
