Key Fob Trouble
2003 Mercedes C320 Sport Sedan
Key Fob Trouble
I'm having some trouble with the lock button on my key fob. Although everything else works fine (i.e. lock button, trunk button, and panic button), my lock button is not functioning. Two weeks ago, it was at a point where I would have to click it a few times until it would lock the doors. And last week, it didn't function whatsoever, no matter how hard I pressed or how many times I hit it. although the other buttons were functioning perfectly fine. All of a sudden last week, I hit the lock button, and sure enough it worked. It stayed like that for about 4 days, working perfectly fine, and now its back to not working at all. any ideas? I know I'm most likely going to have to have it replaced, but just out of curiosity, does anyone know why this is happening?
thanks
thanks
OK, next step. Does the other key work perfectly fine? Just making sure it's the key and not the receiver in the door handle.
If the other key has no troubles, then yes, probably have to bite the bullet and get a new key.
i have frequent problems with my remote like that...replaced the batteries several times...plust my range blows...my g/f key fob for her mustang works like a mile away and mine i have to not only be in sight but at most 10-15 yards away and sometimes it doesn't work at all. Really gay.
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Guys, & remember that unless right on top of the car where IR works from the key to the door handle window - long distance is over RF via the antenna imbedded in the rear screen. The stick on connector centre of rear screen under the head lining & the antenna amplifier in the C pillar LHS. A malfunction in any of these will mess with key fob locking performance. Check all of these for good connections & earthing. Sticky pad at rear centre top of screen sometimes lets go. Give it a shove.
Have you had a tint done recently - they frequently cut the antenna wires as they come out of the screen or get water in the amp. There are many threads covering this.
Last edited by Glyn M Ruck; 07-12-2010 at 10:20 AM. Reason: correction typo LHS not RHS C pillar
Super Moderator
Mav - your problem is typical of an RF problem - I see you have tinted windows. If that is a metallic tint then that is why you have a problem. Metallic tints can completely destroy RF reception. How is your radio reception?
2002 C230 Kompressor, Capri Blue
That is what is wrong with my 2002 c230, I have metallic tint, my key fobs stopped working and my radio reception is terrible. I am going to change it very soon.
Super Moderator
Good luck
Super Moderator
The sticky connector pad is top dead centre of the "rear window" of the car just under the head lining. See diagram which I know is confusing. If you poke your head onto the rear parcell shelf you can see the wire trace in the glass running to the connector.
Super Moderator
![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
Super Moderator
You fellows had better start brushing up on your Mandarin.
2007 W203 SS
Super Moderator
on older w203s like mine it has two ir sensors one on each front door. On newer models they took off the passenger one to save money. They are known to have issues in sunlight,heat and have to be replaced. I have been lucky both of mine are still fine but there are a lot of people on here that had to have it fixed under warranty. GL
As should you - we will all be assimilated. ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
As I've said before, get the mods4cars module; you'll never have to worry about your receiver not picking up your signal again (except for those with metallic tint on their screens, I mean windows - must not let them win).
Super Moderator
Yes - that is my understanding. Also see Trey's correct reply.
Super Moderator
Yes - I try hard but find Thai easier. But the future will likely be Panglish & Mandarin
2007 W203 SS
