recalls
Old Jul 20, 2010 | 10:55 PM
04mbc230's Avatar
2006 C230 Sedan
recalls
I have recently pulled the recalls on the NHTSA Service Bulletins and for the year and model there is 9 FOUND.
did this one ->>>1. SB-2009100001 date:12/01/09 Replace camshaft adjustment solenoid and install adapter harness(es)
2. 470036 date 05/01/09 Fuel guage system level does not match the acutal fill level in tank vs at the instrument cluster
3. PB-91-60-53A date:02/27/09 SRS indicator lamp is illuminated and code b1058 and b2db0 are stored, replace srs control unit.
4. PB-82-10-376F date:02/06/09 xenon or bi-xenon headlamp not functioning
5. PB-42-30-103 date: 01/13/09 anti-brake system (ABS) return flow pump running without control with corresponding fault code c1401, clean and insulated the connector for the return flow pump relay.
6. 452046 date:12/04/08 steering rack and pinion at play
did this one ->>7. 2008020002 date:08/01/08 engine vent hose not conform to specs, cracks may develop and over time result in rough running engine.
8. 033008 date:04/28/08 check enginee light on / fault codes fc1200/fc1208 stored in me-sfi control unit.
9. 2008010001 date: 02/20/08 check catalytic conversts and replace if necessary
I had 2 of the 9 completed at the dealership and 1 of them I had to ask in order for them to do it.
So with that in mind, how many of you had all those 9 completed. Just wondering.
Old Jul 21, 2010 | 11:45 AM
04mbc230's Avatar
2006 C230 Sedan
No one has these issues or done any of this work?
Old Jul 21, 2010 | 01:06 PM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
if you call your local MB dealer (service desk), give them your VIN and ask them if there are any TSBs/recalls pending on your vehicle. They will be be able to look up and tell you 30 seconds.
