DIY: Hid Convert Kit Install - VVME product
#51
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
#52
We did the xenon = present today. and it worked. no errors no flickers. everything stable.
Good thing, since i am a student at wyotech fremont, one of the instructors use to work for mercedes. he got the star diagnose/is software and we did it.
#54
e350 09
hmmm,,,,,,,,for the headlights problems,,, you can refer to
their VVME HID KIT INSTALLATION guide....
http://www.vvme.com/documentation_do...-guide.html#h3
#55
e350 09
not yet..... if you install the VVME HID KIT by their specification , it should be no problem....
anyhow, i searched in google last days and found there are so many posts in different car forum mentioning that they use VVME HID KIT or DDM ,and i found a funny post to compare VVME HID KIT with Speaker,DDM and VisonX4601 kit,,,,
http://talk.newagtalk.com/forums/thr...asp?tid=160631
in the post , the poster present different effect of these brand hid kit..........
by comparison, "VVME kits are cheap, reliable, and almost identical to the factory HID on the tractors and they are not blue like other kits."
so, what is your opinion ???? just post your fair judgement here........
#59
I have factory HID's with xenon set to present and want to add this too my fogs. Do I need 55w or 35w? And will these bulbs fit into the fog lights? xenon bulbs are long after all..
#60
2003 c240
You should get 35W. The small space of the foglight might cause it to melt using a 55w.And yes it will fit.
#61
e350 09
of course those bulbs fit into fog lights... as for which to choose, 55w or 35w , it is depends on what work effect do u need....
35w is digital ,, firstly, u can refer to the difference between 35w and 55w kits....
http://www.vvme.com/documentation_do...omparsion.html
#64
2003 c240
no you wont need a relay. The factory wiring can handle the HID's and if you get a relay harness it only switches from one light so you will get a bulb out warning for whichever side you dont use for your switch.
Also, the xenon=present doesn't affect the fog lights. It's only for the headlights. And when plugging in the ballast on the foglight you may need to install the wiring harness backwards.
#65
install it backwards? what do you mean exactly? like reverse the polarity by switching the plug around?
#66
e350 09
#67
2003 c240
#69
should be here end of this week i hope so I can install this weekend
next I just gotta figure a way to aim fogs a bit higher so that actually shine light down range
#70
2003 c240
THe fogs are meant to shine real close and wide for poor weather conditions.
#71
yes while I realize that, they don't do much use when I cant even tell they're on when I turn them on...
#73
2003 c240
edit: I just realized you have the amg foglights, you might get better results than me since they are clear and designed differently.
#75
