Lug Bolt Question
Old Aug 2, 2010 | 10:41 AM
omg its nate's Avatar
06 C230 6 Speed FTW
Lug Bolt Question
06 Sport with 12mm Spacers up front. What size lugs should I get?
I have some 40MM EXTENDED STUD BOLT 12X1.5 lugs would that work?
Old Aug 2, 2010 | 12:23 PM
zerocover's Avatar
2007 C280 4Matic
Whats the length of the factory bolts + 12mm?
If its 40 then yes
Old Aug 2, 2010 | 01:01 PM
06 C230 6 Speed FTW
I guess I am not sure what the factory length is. I will do some more searching.
Old Aug 2, 2010 | 01:04 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Take on out and measure it. Probably will be faster.
Old Aug 2, 2010 | 01:34 PM
06 C230 6 Speed FTW
At work and the car is at home. I thought it was around 23mm.
Thanks for your help.
Old Aug 2, 2010 | 01:36 PM
06 C230 6 Speed FTW
12mm thread and a 17mm head is what I came across when searching. Sounds right.
Old Aug 2, 2010 | 01:43 PM
e1000's Avatar
a quarter mile at a time
12x1.5 is the thread specs, you need the shank length + 12mm.
Old Aug 3, 2010 | 04:55 AM
phister's Avatar
06 C230 SS 6spd
yeah you can always call up radusadirect and they'd help you out
Old Aug 3, 2010 | 09:07 AM
06 C230 6 Speed FTW
I took the blots out last night and measured. Thanks
