Torque specs from shop manual (brake repair)
I do not have the W203 MB shop manual (on CD) anymore, and would appreciate it very much if someone in posession of one could look up some information for me for a 2006 C230 Sport Sedan. I was in need of the torque spec for the front and rear caliper bleed valves, and the nominal psi rating for pressure bleeding the system. I recall the information was contained in the section describing bleeding of the service brakes.
Thanks in advance.
Normal PSI should be from 10-25 PSI if you're using a pressure bleeder if I remember correctly.
C:\Users\john\Documents\Motor Vehicles\Mercedes\Brakes\Brake Flushing.mht
I made one of these :-
http://www.bmw-m.net/TechProc/bleeder.htm
It amazes me that MB has seemingly cataloged a torque spec for every threaded fastener - regardless of it's importance or whether it is part of a bolt pattern. But then, maybe I never looked deep enough in other workshop manuals.
