Will these spacers work?
Old Aug 11, 2010 | 11:51 AM
magictoilet's Avatar
'12 P31 C63 coupe
http://cgi.ebay.com/ebaymotors/ws/eB...m=260590808970
These are like a third of the price of H&R's, etc. I have 19x8.5's in the front, 19x9.5's in rear and I know I can fit 20mm in the rear and 15mm in the front, but I want to make sure these can fit on my rear's since I thought rear spacers are different than front spacers but it doesn't say that anywhere in the auction.
Old Aug 11, 2010 | 01:32 PM
e1000's Avatar
a quarter mile at a time
Seems like they would work, the bolt pattern is the corect 5x112. I would shoot the seller a message asking if the centerbore is 66.56 (66.6) and if both the 15mm and 20mm have the hubcentric lip on them. You should be more worried about the front than the rear. The front hubs on the w203 are really long and taper up to the final thickness of 66.56 sometimes causing trouble with spacers.
Old Aug 11, 2010 | 01:48 PM
Javvy's Avatar
13 Jeep JKU Sahara w/4" lift Kit & the works,2015 Toyota Sienna XLE,2013 Hyundai Sonata Hybrid
my experience, when I bought these cheap spacers I was not confident at all about their performance, they seam like they would get crushed under all the pressure and force.........I bought H&RR and they were super solid and you can be sure that they will absolutely not fail.........again this is just my 2cents......forgings can be of different kinds........gravity feed castings v/s pressure casting which compact the material more.........these are definately casted ones and will be super brittle........
