DIY 722.9 7G-tronic 7-speed automatic transmission service thread
Rating: Thread Rating: 8 votes, 5.00 average.
Old Today, 12:52 AM
  #376
joelL's Avatar
clk 500 7 speed 722.9 issues with 2gear and 6 and 7 not recognized
hello I have a clk 500 2005 with the 7 speed 722.9 did a service on the transmission and took the valve body apart I put everything where it supposed to go and I'm having bad luck car drives but when u put in gear D it starts in 1st then revs on 2 second gear and jump to 3 then is fine till it gets to 5 but don't recognize 6th or 7 gear also when I come to a stop it goes straight to 3rd gear not even 1st but I get a code 0894 mean the gear is unreasonable or the transmission is slipping I have opened this damn tran more the 10 times but I have also read that after cleaning or replacing the transmission solenoid you need to re set the relearning value to 0 .. Just not sure
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
Quick Reply: DIY 722.9 7G-tronic 7-speed automatic transmission service thread
