Blew tire at 80mph...
So was on my way back to Maryland from Florida when my car started slightly pulling to the right and a slight vibration began. Keep in mine I'm still at 80mph. So I slow down and it seems to go away so I speed back up then the vibration picks back up. I said ok fine you got me I'll pull over.
Next thing I know I have a flat rear tire (less than a year old and less than 10k miles on them Nitto NT555). No nails or any objects that penetrated the tire. When I get it to the tire kingdom (46 miles behind me) who was the only place that could find a 265/30/19 tire the next day i saw this. My tire is missing about an 8" section out of the inner side wall and of course the rest of is is like string cheese from being melted down by the rim running on it at 80mph for 100 yds or so.
Super Moderator
You were lucky man i hate tires. It actually scares me to drive on highways know because of my accident because when a front tire goes you loose almost all control if you are at high speeds. That is why i will always put only the best tires on my car and make sure they are in good shape. Glad you are ok how is the rim?
I always run a major manufacturer Z-rated tire or better. It also helps to have the TPMS system turned on if you can find someone to do it. It told my wife immediately that a tire had failed when it happened to her at a similar speed.
I didnt think we had tpms standard. especially since I'm running aftermarket 19"...but ya I was running high end tires (Nitto NT555). Rim isn't too bad actually luckily the tire folded underneath the tire perfect and only a little checker printed on the very tip of the lip which is covered up when the tire is inflated correctly (thank God). and ya luckily it was my rear tire and not my front.
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Are you running stretched tyres to prevent rubbing? Looks like you might be with that wide lip. Operating tyres stretched is looking for a failure. The tyre is operating outside it's design parameters. Fit Michelin PS2's
The aftermarket Hella system that I put in the American wife's Audi is a lot better. Her TT comes with a compressor and a can of stop leak (a lot of good that would have done in your case) in place of a spare tire.
The Hella system uses sensors that alarm not only at set levels but also at rate of change in pressure or temperature. The rate of change warnings give you half a chance to get stopped before the tire frags itself.
ya no they aren't stretched really. At least they are the size that was recommended from tire rack.
Super Moderator
2007 C230SS; 2014 ML350 BT
2006 C230 6speed/14 C63
Passive TPMS can be activated by STAR with developer mode. Although it is not as active as a true active TPMS, it does work pretty well, and would have surely told you before that tire blew out. The passive system uses the ABS sensors to monitor revolutions at each wheel.
and ya unfortunately I won't be down in the burg until prolly christmas with my car (maybe thanksgiving) but ya man I'd love to get a meet together at a quaker steak and lube or soemthign!
'14 CLA 45
The best and most expensive tire will do you no good when you lose air in a tire and keep driving.
I had a similar experience a few years back. Car was slowly pulling to a side for a few minutes. It was windy and I figured it is the wind in addition to the already slanted road. I could not have been more wrong. Luckily I was only going 45mph and nothing bad happened other than me having to replace the two front tires as they were past 50% life.
Check out Orange TPMS - http://orange-electronic.com/eng/07product/main.html
It is an active TPMS with a nice display and very easy to install for any tire installer. I had it for 3 years now and it paid itself off more than 3 times. I bought it at tirerack back then for $160 but you can get them off Ebay for cheaper. Forget the passive TPMS. It will most likely cost you more and is in no way as good as this one.
2007 W203 SS
I'm glad to hear that you and your MB fared well through what could have been a disaster. I remember you stating in another post that you were running 45/50+ PSI in your tires. Are you still running those pressures? I can tell you that an extended run on the highway at those speeds will generate enough heat to disintegrate those tires and the internal PSI will exceed the 50 psi you checked when cold. As a matter of fact, it may have exceeded the manufacturers max recommendations causing the inevitable.
A more likely failure mode in the case at hand was a slow leak causing the tire to overheat from excessive flexing and fail all at once. It's a common thing to see cars in the summer Arizona heat with a shredded tire for this reason. One of the best features on the Hella aftermarket TPMS that my wife's car has is rate of temperature change alarm.
2007 C230, S2000
Glad to hear you survived this incedent. Blowing out a tire at that high rate of speed is very dangerous.
About TPMS, I'm not particularly fond with them. I regularly check my tire pressure and the wear and tear of my tires. I guess it's a habbit I developed for autocrossing and tracking.
My Jeep GC has one and during winter it always turns on until I get to drive it for a while.
ya i dropped the pressure down to around 40-42...and there shouldnt have been a leak as there was nothing found in the tire as in punctures etc
