C32 brakes questions.
Old 04-29-2003, 01:32 AM
  #51
MBworld Guru
FrankW's Avatar
white and whiter
yep, almost all the new MB's brake are made by Brembo now.
Old 04-29-2003, 02:02 AM
  #52
bajaiman's Avatar
01 C200 Kompressor, 02 C32 AMG
AMGs only or all MB?? ... I wonder why the C32 brakes cost a lot less compared to the normal Brembo aftermarket brake kits...after all they all came from the same factory...
Old 04-29-2003, 04:40 AM
  #53
Mach430's Avatar
I believe only the calipers are actually made by Brembo. As many have pointed out, there isn't that much technology in the rotors... They are heavy, reverse directional (one is backwards), 1-piece, etc. For many models, Brembo offers a 1-piece and a 2-piece upgrade using the same caliper, and usually having a $1,000 difference in price. Manufacturing a hat for a 2-piece rotor specific to the car can be very expensive (added to a bigger/better rotor). Only a handful of people will upgrade their brakes to a Brembo GT kit, compared to those who will purchase C32's, and have the factory upgrade. Being that Mercedes buys in mass quantities, and that they are not as technologically advanced as a 14" kit, they can sell at much cheaper prices.
Ben
Old 05-11-2003, 11:41 AM
  #54
JeT
JeT's Avatar
Hey Baj, thanks for the pics.
Make sure you post pics when you have the suckers on. I'd be interested to see how they look behind the Star III's.
Old 05-12-2003, 07:50 AM
  #55
bajaiman's Avatar
Jet...that suckers will be installed next week tuesday...I'll post some feedback....so stay tuned ....damn I can't wait!!
Old 05-12-2003, 09:40 AM
  #56
pcbchow's Avatar
C200K
i have fitted the C32 AMG rotors and calipers in my car, i dont wanna spoil your day, but franky i am a little bit disappointed,
the rotors are directional but one direction only, so if i can remember correctly the right hand side is wrongly sided...
i suggest you can get some that can do the job properly to fit it, make sure you put in the appropriate brake fluid "DOT 4", and release all the "air" in ALL FOUR brakes both front and rear, the first time i have it done, the guy forgot to release the "air" at the back, so i have get another guy to do it again, but still...... so on the third time i put in steel cables too, it feel much better, so i suggest you should fit the cables too
i have it for almost one month, my comment is it stops pretty good but not as good as i have expected, also you can feel the front can stop but whereas you can still feel a little bit push or force from the rear, cos i did not change the brakes at the front, so i guess thats the downside
Old 05-12-2003, 10:35 AM
  #57
bajaiman's Avatar
Where did you get the steel brake lines?, what brand? and how much?....I've been looking for them but I couldn't find any...
Old 05-12-2003, 11:08 AM
  #58
pcbchow's Avatar
C200K
i guess there is a little bit difficulty here cos you are in sydney and i am in hong kong, so even i tell you where i got it still doesnt help, anyway i got my C32 brakes for HK$5,680 divide that by 5 (roughly) then you will get the aussie $ equivalent and my steel line for HK$1,800 all 4 lines front and rear
but as i said its good idea to fit the steel line too, thats my own personal experience
Old 05-12-2003, 10:41 PM
  #59
antonio's Avatar
2002 C240 Classic
can i just get the AMG calipers and then buy a set of brembo cross-drilled directional rotors from evosport? are there any "extra" pasrts i need to do this conversion or just the calipers and steel brake lines?
Old 05-12-2003, 11:03 PM
  #60
bajaiman's Avatar
I think AMG rotors are good enough....well they're good enough to be fitted on the C32
Hopefully I can get the stainless steel brake lines to be custom made locally. So far it looks promising as I've made some calls and they said that they can do it as long as I got the factory sample.
Old 05-20-2003, 09:23 AM
  #61
bajaiman's Avatar
Before and after pics ... sorry for bad quality picture...
Old 05-20-2003, 11:12 AM
  #62
carlssonist's Avatar
2002 mercedes c320
That's a big difference, indeed.
How much do you spend your money on brakes ?
Is there any difference in the braking quality ?
Old 05-20-2003, 11:54 AM
  #63
bajaiman's Avatar
I bought the C32 front brakes for about US$900 including brake pads, it cost a bit more here in Australia but I believe that you can get the same thing in US for about US$700.
Braking quality??... I can feel the brakes now bite harder than the stock ones, but I think theres still more room for improvement as the brakes are still in breaking in period for another 200km.
Old 05-21-2003, 02:46 PM
  #64
tomz_racing's Avatar
c320 (w203)
Where can i get those for $700 ?
Old 05-21-2003, 03:15 PM
  #65
HigHal320's Avatar
02 C320, Brilliant Silver
damn.. they look nice!
AMG should also make one like that for the rear wheels.
Old 05-21-2003, 06:15 PM
  #66
bajaiman's Avatar
You can try Evosport
Old 05-21-2003, 08:06 PM
  #67
c320 (w203)
is that the full complete set ?
Old 05-21-2003, 08:20 PM
  #68
bajaiman's Avatar
It should be a complete front brakes assembly (2 rotors, 2 calipers and brake pads).
Old 05-21-2003, 10:06 PM
  #69
c320 (w203)
so how about the rear brakes ?
Old 05-21-2003, 10:14 PM
  #70
Lynn's Avatar
According to KLEEMANN W210 E55 brakes will bolt right on. He made a couple of posts and one has the part numbers.
Old 05-22-2003, 12:02 AM
  #71
Former Vendor of MBWorld
Brandon @ Kleemann's Avatar
The W210 E55 AMG rear brakes are a direct bolt on. I installed them months ago on my wifes Coupe (they will fit any W203). No special modifications required.
Stainless steel lines were impossible for me to find- I tried every source in the US I could think of. All I got were replies that they could be custom made from specs of a standard set etc. I had a set made locally with swaged fittings. They greatly improved the pedal feel, much firmer. I paid approx $200 for the set of four lines.
Old 05-22-2003, 01:13 AM
  #72
bajaiman's Avatar
Kleemann…would you have any idea how much firmer (slight, medium, much) would the pedal feel if I only get the front stainless steel lines and still using the stock W203 rear brakes??
Old 05-22-2003, 04:23 AM
  #73
pcbchow's Avatar
C200K
much firmer! the first few times i step on the brake paddle it locks up the wheels and abs kicks in but you will get use to it after a while as i said before it is highly recommended i love it and it feels much better and firmer
Old 05-22-2003, 06:56 AM
  #74
bajaiman's Avatar
I'm aware that you've changed all your brake lines...I'm just wondering if just changing the front would be as firm as changing all four.
Old 05-22-2003, 01:02 PM
  #75
Mach430's Avatar
I will be offering a special purchase price on the C32 brakes later today!
Quick Reply: C32 brakes questions.
