Help, I'm losing my boot!
01 Corvette, 05 c230, 99 Grand Am
The boot around my shifter just pulled loose, any thoughts on how to re-attach it? It's just sitting there and doesn't seem to clip in anywhere...
![](http://rscpro.com/files/merc/boot.jpg)
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
The best fix is to replace it. Someone has a thread on how to fix it with paper clips but that's really a botch job.
Looks as though the rear clip has gone.
Botch job? Uh, that was me spank boy, and it works just great.
Since they don't sell the surround piece with the clips, and the whole assembly is 150 or more, I'd say it's quite good!
Pop the trim piece, remove the gear shift knob and leather boot, drill some tiny hole through the the side of the plastic where the clips are or were, place into the trim piece, use some paper clips through the drilled holes, and viola.
Put the shift knob on, snap the trim in, and you're done. It will never come off again,
the only caveat is that you must unsnap the trim and remove it, the boot/bezel and the trim as one, and let your mechanic know too.
Super Moderator
Sorry Todd - forgot it was you ![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
I still think it's a botch job but Hey! - whatever floats your boat.
Herr Daimler would be turning in his grave. Benz held together with paper clips!
2007 C280 4matic Avantgarde
[quote=C230 Sport Coup;4240158]Botch job?
Pop the trim piece, remove the gear shift knob and leather boot, drill some tiny hole through the the side of the plastic where the clips are or were, place into the trim piece, use some paper clips through the drilled holes, and viola.[quote]
so how do you remove those 2 things?
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Super Moderator
[QUOTE=ontmiss;4240349][quote=C230 Sport Coup;4240158]Botch job?
Thats a good question, how do you take the whole thing apart? Does the shift knob just screw off?
Super Moderator
Super Moderator
2007 C230SS; 2014 ML350 BT
I think you meant "f---kwit" ![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
I like Sportstick had never heard that before.
For everyone else that missed it:
To spice things up & regain momentum I think:
Cretan, moron, mental paraplegic, goof, jerk, nerd, schmo, schmuck, turkey, idiot, imbecile, jackass, mooncalf, nincompoop, nitwit, f---kwit, blockhead, boob, dimwit, dingbat, dolt, dope, dork, dumbbell, dummy, dunce, fool, halfwit, ignoramus, imbecile, lamebrain, loony, loser, retard, bonehead, buffoon, dumb ox, dunce, dunderhead, fathead, twerp, twit, lightweight, loon, birdbrain, sucker, dick, ***** and other derogatory terms should be encouraged.
![Popcorn](https://mbworld.org/forums/images/smilies/popc1.gif)
Super Moderator
MBworld Guru
white and whiter
i remember you could order just the chrome. that was the quote i remember i got from my parts guy. maybe they changed it again? either way I didn't even end up buying new chrome piece since I take them apart a lot when I was installing all kinds of stuff, so i would've probably broke them again. ended up just velcro the thing down and it works nicely.
Thanks!
