Old Jun 29, 2015, 04:08 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tire Repair and Maintenance
Print Wikipost
changing tire..
Old Sep 11, 2010 | 09:55 AM
Paculdo's Avatar
06 CTT-S
changing tire..
noob question guys..
ok.. i blew the left front tire.. and now trying to replace it.. raised the car (jack) and took all 5 lug nuts off the rims.. i can't take it off.. i'm banging the wheels a bit but i'm worried that if i bang it too hard, the tiny jack may slip, etc..i have the tire up that it's not touching the ground..
am i missing any thing? do i need to take off the center cap and loosen something? this is my first time changing the tire.. i need to take this to discount tire later to buy new front tires..
e-brakes off, and it's on Park.. to i have to set it to N(eutral)?
thanks..
(06 c230 SS)
Old Sep 11, 2010 | 10:08 AM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
no its normal...mine were a b.i.t.c.h. to get off the first tiem I ever removed them...theyr'e plastic rings under there and tend to get compressed...just keep trying they'll come off...try hitting the tire with something!
Old Sep 11, 2010 | 10:35 AM
Paculdo's Avatar
06 CTT-S
i'm actually kicking it now and the car is shaking.. i'm worried that the jack (support) may slip or something.. would a lubricant work? wd-40?
Old Sep 11, 2010 | 10:38 AM
Paculdo's Avatar
06 CTT-S
changing tires..
this is how it looks like..
Attached Thumbnails changing tire..-41167_1560563327557_1039517935_1605908_8076114_n.jpg   changing tire..-59085_1560562927547_1039517935_1605907_4084303_n.jpg
Old Sep 11, 2010 | 10:51 AM
ontmiss's Avatar
2007 C280 4matic Avantgarde
Call roadside assistance (1-800-FOR MERCedes) and let them deal with that. It's free of charge as far as I know.
Old Sep 11, 2010 | 10:53 AM
JoeVal's Avatar
C350 Elegance
1. Block the right rear wheel, front and back of wheel.
2. Make sure damaged wheel is freely off the ground.
3. Grab the wheel sides, gear in N, and try to turning it forward and backwards while pulling it off.
4. If unsuccessful, put an ice bag on the wheel metal axle, to contract it to max. Take the wheel cap off and go with ice on the axle outside end too. It ought to come off (use a plastic mallet, frontways and sideways).
Plastic wheels? Woaaaah! Good luck.
JV
Old Sep 11, 2010 | 11:30 AM
samaritrey's Avatar
Super Moderator
THE C350
+1 if you don't have proper jack call them you don't want to hurt yourself. My wheels get stuck on and i have to get my rubber mallet out and smack the crap out of them to get it off.
Old Sep 11, 2010 | 06:59 PM
maverik259's Avatar
you sure mercedes roadside is free? that just doesn't make sense for the pure reason "mercedes" is in the title of it!
Old Sep 11, 2010 | 07:11 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
its free while your under warranty. You just need a breaker bar. The mud and water makes the lugs seize from being on there so long. A breaker bar should allow enough torque to loosen the bolts.
Old Sep 11, 2010 | 07:17 PM
97W202's Avatar
2006 C230 6speed/14 C63
u sure? they have came and put my spare on at 3am before at no cost and I am about 7000 miles out of warranty...
Old Sep 11, 2010 | 07:21 PM
TemjinX2's Avatar
i know its offered under new car warranty. i dont know if its offered without charge afterwards. I could be wrong, i just use AAA anyways.
Old Sep 11, 2010 | 07:27 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Actually, everyone, this stuff is free for the LIFETIME of the vehicle - no matter how old it gets, no matter how many owners it has. As long as it drives down the road it is covered under Mercedes Roadside assistance. They will bring you gas and change your tire for free. This applies even if you are simply borrowing someone else's Mercedes.
As far as I know, Mercedes is the only company that provides 24HR roadside assistance for the lifetime of the vehicle.
OP: My rims have never been stuck on, but they're taken off and put on every 6000 miles when I rotate across axle. If I were you, I'd definitely let Benz roadside handle it. They've changed a tire in my driveway before. I'm simply not good with tools and do not like getting my hands dirty.
Old Sep 11, 2010 | 07:30 PM
97W202's Avatar
germans...
Old Sep 11, 2010 | 08:49 PM
ontmiss's Avatar
http://www.mbusa.com/mercedes/contact_us/overview and select FAQ "Is my vehicle covered by Roadside Assistance even............"
Mercedes Roadside Assistance comes with EVERY Mercedes vehicle, no matter how old.
It is 24/7.
They provide for free :
1) Jump start
2) Install new battery (free labor, you buy the OEM battery that they carry on the truck, so you get the full MB warranty on the battery, and a record of replacement on file at the dealer)
3) Install your spare tire (remove flat install spare)
4) Deliver a couple gallons of gas or diesel to get you to the nearest gas station.
Everything above is on Mercedes Benz's tab.
Roadside is available to do more services as well, such as lockouts, minor repairs etc, but they do require a fee.
As for lockouts, if your vehicle has an option for tele-aid, it becomes totallyworth it if you are stuck someplace with your keys locked in, to be able to have the MB satellite unlock your car for you!
Each dealer has a Roadside Tech with around a 30 mile radius of the shop.
Roadside Assistance doesn't cover towing.
Towing while under warranty is at the manufacturers discretion.
Otherwise, roadside will gladly arrange a tow for you, so you don't have to fuss with it.
The benefits of using MB roadside are great. We know about the vehicles. We have the special tools. You can stay warm and dry while somebody rescues your stranded vehicle.
https://mbworld.org/forums/c-class-w...ce-info-4.html
Old Sep 11, 2010 | 09:45 PM
EV0LVE's Avatar
F10
kick the tires, it'll come off.
Old Sep 11, 2010 | 11:07 PM
TemjinX2's Avatar
wow thats impressive. Some thing from mercedes that doesnt cost you one of your first born.
Old Sep 12, 2010 | 12:49 AM
phister's Avatar
06 C230 SS 6spd
do you not have any jackstands to put under the car besides it being on the jack. What I always do if I dont have my jackstands is to put the spare tire under the side of the car beside the jack that ways if it falls itll land on the tire and not crash into the ground possibly breaking some suspension components. It's probably just on there from all the dirty and debris from the roads. Try using a rubber mallet and just smacking the tire from one side to the other.
Old Sep 12, 2010 | 12:17 PM
Paculdo's Avatar
06 CTT-S
thanks all..
i called a friend and kicked it (big guy).. yeah.. he did place the spare "donut" under the car for precaution (although it's thin)... for one noob question, i learned a great deal about the MB road assistance.. didn't know about it 'til now
