No hands... drift to one side
Old Sep 21, 2010 | 10:25 PM
Tom P.'s Avatar
2011 C300 4Matic
When I let go of the steering wheel, the car will track towards the right side and needs manual intervention after about 5 sec. Most roads are crowned in the middle so this drifting to the right may be attributed to that but it does it even on what appears to be a flat road surface. Note this is a gentle drift to the right... like I said it takes about 5 seconds before I need to steer left just a bit to correct it. Should I get an alignment? How long does your car track straight with no hands?
Old Sep 21, 2010 | 10:36 PM
jcnash's Avatar
2002 Mercedes Benz C230 Coupe
A fellow Candian eh?? :P
My car used to track straight despite the crown in the road for 2-3 minutes after which the bumps/irregularities in the road cause the steering wheel to turn which in turn causes the car to veer.
Definitely get an alignment if your car starts veering as soon as you let go of the steering wheel.
Im getting one too because I got all 4 front control arms changed recently.
Old Sep 21, 2010 | 10:38 PM
jogger's Avatar
02 S500
might it be this? http://www.tirerack.com/tires/tirete...jsp?techid=47&
Old Sep 22, 2010 | 07:18 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
check your caster settings. Bad caster can cause the car to drift to the right.
Old Sep 22, 2010 | 08:43 AM
Glyn M Ruck's Avatar
Super Moderator
Set the castor one degree more positive on the RHS than the driver's side. Typically 9.6 deg & 10.6 deg. This will stop running off to the right with the camber of the road.
You will need the fluted 3 way bolts in the castor bushes to achieve this.
MBSA have drummed this into every alighnment shop in SA.
Old Sep 22, 2010 | 10:41 AM
jcnash's Avatar
Good advice!
Im going to follow this too when i get my alignment done tomorrow.
