Please help me identify this hose thing!?
My 2002 c230 kompressor coupe threw a lean code. I was checking out the engine and found this hose was completely disconnected and its rubber thing that helped it connect was torn. I've searched and can't find anything that would lead me to find out what this hose is and I need to use this car this weekend for some crappy wedding. Help me please? I'll give you cookies?
03 g35 coupe...........02 c32 Sold
it looks like a vaccum tube for the throttle body. Your probaly throwing a lean code because you have a vaccum leak caused by the ripe in the tube. I would just take the tube and find a matching size rubber tube at autozone or home depot. It'll probably cost you a $1, some times they throw it in for free if you buy something else with it.
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
![](https://mbworld.org/forums/attachments/c-class-w203/192644d1285497106-please-help-me-identify-hose-thing-m111-vacuum-fittings.jpg)
5 A 123 276 16 30 LINE
BLACK/RED
4X1 MM [404]
NB
5 A 123 276 19 30 LINE
BLACK-GREEN
4X1 MM [404]
NB
5 A 000 276 00 30 LINE
WITHE
4X1 MM [404]
NB
5 A 000 276 01 30 LINE
RED
4X1 MM [404]
NB
5 A 000 276 02 30 LINE
GREEN
4X1 MM [404]
NB
5 A 000 158 14 35 PIPE LINE
TRANSPARENT
4X1 MM [404]
NB
5 A 000 158 93 35 PIPE LINE
TRANSPARENT/BLACK
4X1 MM [404]
NB
5 A 001 158 01 35 PIPE LINE
TRANSPARENT/VIOLET/BLACK
4X1 MM [404]
NB
8 A 001 997 81 52 HOSE
BLACK
4X0.75 MM [404]
NB
11 A 001 997 38 52 HOSE
Replaced_By: A 008 997 60 82 -
11 A 008 997 60 82 HOSE
Replaced_By: A 000 987 26 27 -
11 A 000 987 26 27 PLASTIC PIPE
BLACK
6X1 MM [404]
NB
14 A 008 997 90 82 HOSE
BLACK
8X1 MM [404]
NB
17 A 117 997 09 82 HOSE
8X3.5 MM [404]
NB
18 A 007 997 61 82 HOSE
9X3.5 MM [404]
NB
19 N 040621 1005200 INSULATING HOSE
5X0.6 MM [404]
NB
19 N 040621 1008200 INSULATING HOSE
8X0.7 MM [404]
NB
20 A 201 997 50 82 HOSE NB
23 A 117 078 02 81 HOSE NB
23 A 617 078 09 81 HOSE NB
26 A 117 078 04 81 HOSE NB
29 A 107 833 01 97 HOSE
Replaced_By: A 117 078 05 81 [421]
29 A 117 078 05 81 HOSE NB
32 A 117 078 06 81 HOSE NB
32 A 117 078 07 81 HOSE NB
35 A 117 078 08 81 HOSE NB
38 A 111 078 00 81 HOSE NB
41 A 120 078 01 81 HOSE
Replaced_By: A 140 476 15 26 -
41 A 140 476 15 26 HOSE
Replaced_By: A 120 078 01 81 -
41 A 120 078 01 81 HOSE NB
44 A 111 078 01 81 HOSE NB
47 A 602 078 06 81 HOSE NB
50 A 120 078 03 81 HOSE NB
52 A 601 078 02 45 BRANCH-OFF FITTING NB
54 A 116 276 09 29 NOZZLE
(CONNECTOR),YELLOW
4 MM/4 MM NB
56 A 000 987 11 45 LOCKING CAP NB
I replaced it with some vaccum tubing from a kragen. Cut what I needed then put 2 clamps on it and cleared the code. Hopefully it won't come on again.
Thanks for all your help!
