CD Player not switching off
Old Sep 28, 2010 | 02:31 AM
spetz's Avatar
1994 E220 Coupe
My friends 2001 C200K has a recurring problem.
His CD player doesn't switch off. This happened about 6 months ago and he replaced the CD player with another OEM part, and now it has the same problem.
It won't switch off with ignition off, neither when the power button is pressed. He had to pull the fuse out.
Why does this keep happening?
Is it a common problem?
Is the only solution a new CD player?
Old Sep 28, 2010 | 06:13 AM
phister's Avatar
06 C230 SS 6spd
interesting... have you tried taking out the radio and looking at the wiring harness. maybe the ignition wire is connected to a consistant power source.
Old Sep 28, 2010 | 06:50 AM
spetz's Avatar
1994 E220 Coupe
Well, it was working fine before all this happened.
And anyway, pressing the power button on the radio doesn't turn it off, which even with the car running it should do so
Old Sep 28, 2010 | 08:55 AM
Glyn M Ruck's Avatar
Super Moderator
Can we just clarify - Are we talking about the OE Audio 10 radio with built in CD player that won't turn off? Or is it an Audio 10 that takes 1 CD but has a 6 CD changer in the glove box & the changer won't turn off from the radio on/off switch or the ignition accessory position?
Old Oct 12, 2010 | 09:15 AM
spetz's Avatar
1994 E220 Coupe
It is the standard radio which takes the the one CD. There is no CD stacker attached to it.
It basically does not switch off. Not when the key is off, and not when the Power button is pressed either
