02 sensor extensions
Old Sep 30, 2010 | 04:00 PM
cpbeasley's Avatar
"annoyance" and "self-righteousness", amoung others...
In regards to a header install and according to Karo, the 02 sensor wires are a tight squeeze....
will an 02 sensor extension work/compatible with m272 sensors? I guess my real question is if all 02 sensor and their accompanying plugs are universal.
they sold them for my old ls1 car, which were necessary with long tubes.
Old Sep 30, 2010 | 05:58 PM
Glyn M Ruck's Avatar
Super Moderator
I don't fully understand your question.
Do not use generic O2 sensors on a Benz - they will screw around. If you extend the sensor pigtales on the harness just do it carefully & ensure good connections. RMeuropean used to sell extenders & new plugs.
Old Sep 30, 2010 | 06:15 PM
cpbeasley's Avatar
I believe you answered it regardless.
To rephrase:
With headers installed on a m272, making the stock 02 sensor wiring reach the new location of the 02 sensor folloing the cat is a challenge without using a 02 wiring extension.
I was asking if the 02 sensor wire extensions are all the same, or if benz has different wiring supplying the 02 sensor, requring a specific wire extender. And if so, where to obtain such.
It sounds like RME supplies the extensions.
Thanks for the info
Old Sep 30, 2010 | 06:16 PM
phister's Avatar
06 C230 SS 6spd
can call up casper they make O2 extension so do other companys like BBK.
