groupbuy on POWERCHIP ecu tune
heres a clip of how to take out ur ecu, hope this helps...
FedEx can eat my $h!t on a plastic plate.
That said, I got my ECU out, and made sure to label all of the connectors.
Super easy to remove with a flat-head screwdriver.
I had to FedEx a computer back in 1999, and they lost it. Misery. Poor little PowerMac G3 never made it home.
He made me use the 8x8x8 box (which sells for about $10 on it's own) and then made me pay to re-bubblewrap the entire thing - after everything was said and done, it ended up being 2.2 lbs.
The guy was a complete d!ck.
The flip side is that, if the ECU gets lost or damaged during shipping, I will be guaranteed an amount to replace my ECU.
There is one on ebay now for $900, that is the same part as mine.
http://cgi.ebay.com/ebaymotors/OEM-M...Q5fAccessories
So I declared $1300.
It may be more or less @ your local shop or stealership.
I think I'm going to go ahead with this, but I won't be able to be without the car for about two weeks from now. First, a few quick questions:
1. I thought the '03 230k sedan was rated at 189 hp, but Powerchip lists 253? Why the discrepency?
2. Would it be unreasonable to list the ECU with FedEx at $1650 ($1300 for the ecu itself and $350 for the flash)?
3. I'm mechanically handicapped. Is the ECU pull easy enough to do for someone that knows nothing about cars?
Easier than reprogramming a SATSCRAM terminal to divert a missile.
http://www.youtube.com/watch?v=RigS2WJUPGs (2:40)
If you call Powerchip, they will email you a PDF with detailed instructions on removing your ECU.
til the end of the month
