Driver door armrest
06 C230 Sport: The armrest on the drivers door that is right next to the grab handle assembly... The material is peeling from the inner plastic mold. Want to remove, inspect, and maybe replace. I have the grab handle off with T20 bits, but are there any other tricks I need to know before going any further to yank the rest of the armrest off? Trying to not break anything, or affect anything of the SRS in the door panel..
Thanks!
anyone have the part number of the driver door arm pad? if not i guess i'll see it labeled when i take it off..
http://bit.ly/bEWSTS
still if someone happens to know a way to reference this driver door arm pad with a part number, please help me out.
thanks again
Although mine is gray and it's not gray anymore. It's also gooey and sticky at times. Seems more of a problem when it's either humid or some moister in the air.
I haven't came to a point where I would replace it, but it's getting there.
still can't believe this happened. it's not like it was tugged on.. no car company is perfect, but i didn't expect this out of a mercedes. not a huge deal though. just sucks it can't be bought separately.
i'll update when i fix.
Thanks,
Andrew
Honestly, taking the door skin off isn’t a big deal. Just roll the window down first and get a set of nor marring plastic interior trim removal tools. Maybe have a few spare OEM perimeter press clips at the ready.
If you pull off the panel, I’m sure you can drill/cut the pad out - but even WIS doesn’t show that…I’m including some detail shots of the set up - it’s a pretty overlapping and sandwiched process…
My pad cracked within a few years of delivery -and was replaced under warranty.
I’d call some local junkyards on a new interior panel - transfer over what you need to from your panel…
