ATF change
Old Oct 31, 2010 | 10:13 AM
mkim331's Avatar
05 C240
ATF change
How often do i need to change ATF on 05 c240. Does ATF change incl. flush?
Should i get it done at MB or local drive in oil places are good enough?
Old Oct 31, 2010 | 10:52 AM
Popo's Avatar
2007 GL450 2005 C55 2002 C32 sold 2001 ML320 sold
I know it is supposed to be lifetime fill, but i would change it every 30-50K depending on how you drive. My dealership only changes the filter and what is in the sump which is basically only half the fluid. These trannys use specific ATF fluid and there is a new spec fluid that can be used in all MB transmissions since 2008.
Unless it is a shop that specializes in Mercedes transmissions, take it to the dealer. The fluid level is critical to operation and reliability and needs to be measured at a specific temperature.
Old Oct 31, 2010 | 05:36 PM
Glyn M Ruck's Avatar
Super Moderator
If you want a troublefree transmission then change oil with the approved product - Fuchs Titan 4134 or from your dealer every 38,000 miles or 60,000 Km like Benz recommend in ROW. Be careful that whoever does this knows what ther are doing. It's not a Ford or GM product.
The choice of flush vs change depends on fluid condition.
See pdf's I posted at the end of this thread on change & flush.
https://mbworld.org/forums/c-class-w...sues-help.html
