review: c240 at 72,000miles
*actually i have a picture of it, but its a bit blurry
These cars are stable as a rock flat out.
Do find it quite impressive that ~168 SAE net horsepower @ 5,700 rpm and a final drive ratio of 2.87 (.83 x 3.46 crown & pinion) can push yours to almost 240 km/h (149 mph)!
No doubt the sedan’s .27 coefficient of drag (.31 in AMG trim) and relatively small frontal area contribute substantially to that figure.
Don’t flirt with Vmax too often around my neighborhood, but the mechanical and aerodynamic directional stability features engineered into this chassis do indeed perform admirably.
Rather like a destroyer crossing a sailboat’s wake.
http://autospeed.com.au/cms/article.html?&A=108676
This is of course at coast - at our higher inland altitudes everything wheezes a bit.
It never ceases to amaze me when getting into lesser cars how much faster they feel as if they are going when pushing them.
The W203 is no Porsche but for a compact family sedan it pretty stable with little feeling of speed.
It easily pegged the speedo at 159mph (obviously speed limiter removed), but at the cost of the car feeling as if it were ready to vibrate apart... I recall tiny window leaks having enough air rush in as if the windows were down, the steering wheel jarred your joints, and air pockets easily shifted the car about... I would compare it to feeling like driving a brick down the highway at those speeds.
+1 w203
-1 f-body
Me thinks you’ll be well served earning your BSEE degree. There are plenty of those highly-remunerative positions available ‘round here.
Indeed. Don’t know the specifics contributing to the Cd figures posted. They were pilfered from MBUSA’s 2004 retail marketing booklet, published in late ‘03. It’s probably safe to assume the cars subjected to testing had their tinwork, tires and other variables/tolerances conveniently arranged just so in order to minimize drag. Almost certain they weren’t measured on the then-available (USA specification) chassis; they were almost high enough to safely straddle a 6x6. MB finally saw fit to install shorter RoW springs here -per relaxed DOT/NHTSA requirements- with its 2004.5+ ‘sports suspension’ #486/949 option. As you’re well aware, relatively minor alterations of ride height and rake can manifest dramatic changes in drag and lift.
Pontiac got in a bit of hot water with our FTC after advertising remarkably low drag figures on its 3rd-generation F-Body. Seems they’d dropped the front end’s ride height well below allowable production specification. The Court ruled that they be sold in that configuration or GM was to revise its claim. Not wanting to replace undercarriages during the warranty period owing to ham-fisted operators, they ultimately relented and subsequently published a revised figure. The EPA nailed ‘em for surreptitiously -contrary to the owner’s manual recommendation- using low-viscosity crankcase oil during fuel consumption testing, too. 5W-30 has long since been deemed de rigueur.
Yes, increasing tire width negatively contributes not only to increased drag, but also rolling resistance. Given proper selection, it’s a worthwhile opportunity cost in many instances. Mine already has enough straightaway speed; enhancing its lateral and longitudinal traction proved a worthy compromise. As an aside, the first time I went really fast was riding shotgun through California’s wine country aboard a new ’69 911S sporting 6” Fuchs and Michelin 185/70VR15s. Doing so may have contributed to my ongoing mechanical preoccupation.
I have a chance to buy an 03 c240 with 4matic. It has about 75000 miles in it and I have never seen a cleaner car. I can get it for $8,000.
Is this a good deal? Any problems that I should be looking for?
Bob
The car hasn't left me stranded yet.
