Alternator replacement help 2003 c320
Another question - I want to get a manual for the car to help with stuff like this. Do you think Chilton or Haynes would be helpful?
I just got this car from a friend at a good price since he was going to trade it in and now trying to see if I should keep it to replace my wife's car (corolla with 130K miles) or if I am opening a can of worms here by going from a toyota to a benz (which has 80K). I drive a bmw 330 and it has a share of its own issues, but I am comfortable working on it as I've had different 3 series (e46) over the last 6 years. All the work so far has been done by me except for computer resets that require a trip to a dealer. There is a huge support for that model though with detailed DIYs posted by people. Browsing the benz forums it does not seem as if there is a lot of info on the c320, so that scares me a bit. That's why I am asking about the books that I can get that will help.
For example, the pdf you posted says things like "remove fan", "remove radiator support", but there are no specific directions on how to actually do it. Maybe it's somewhere else in the Mercedes Service Manual? There are all these bolts and clips so without knowing exactly what to do, i ended up braking a couple of plastic clips, which is annoying. In the end I gave up on removing the fan fearing breaking any more stuff and it turns out it was not necessary from the beginning. For the BMW people have DIYs with pictures for jobs like this and someone would usually mention that removing the fan is not even necessary, even though the book says so. Maybe I am not looking for it in the right place for the c320? Are there other forums I should check out for my 2003 model?
This is one of the best forums for W203. There are several experienced+knowledged folks on this board. With the help of members from this board and MB manual, you should be able to do [almost] everything on your own ... assuming you have the right tools.
About those clips... once you star working on the car, you will quickly learn how to remove the clips and connectors on the car. If you enjoy working on cars, you will definitely learn a lot and save a ton.
Most important thing to remember - do all the preventive maintenance like replacing the trans fluid and filter, replacing all other fluids at appropriate intervals, replacing all filters, etc.
Red arrow is pointing to the "sleeve" I was referring to at the beginning of your post.
If I can get through these issues and decide to keep the car, I will definitely get the book. I have a Bentley manual form my 330 and between that and the e46 forums I solved all the issues with diy. Thanks for your help and if you know anything about P0123 please chime in on my other thread...
