Original Battery! Should I go OEM?
I posted this earlier in the thread but nobody answered me. Will this battery work?http://c2c.activant.com/ctoc/index.j...86A10UX3RTO00A
I personally like Interstate, and if I decided to shell out the money, I'd get an Odyssey battery, which I had on my other car.
2016 Chevrolet SS, 2006 Cadillac STS-V
There's not much on bosch car batteries. Going off consumer reviews NAPA batteries are excellent, the 84 series is considered one of the best batteries around, also DieHard batteries from Sears is rated high as well, and so is Everstart from Walmart, they are produced by Johnson controls which is one of the main battery manf. here in the states.
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
When choosing/comparing batteries, AmpereHour (Ah) rating of the battery is THE single most important thing to look for.
For our cars, 100 Ah is the correct rating. Go with a reputed brand of battery with 100 Ah rating; you are good to go. MB batteries are excellent. On all my cars, MB batteries lasted more than 7 years. You just can't beat that.
Regardless of the age of the battery, when a battery is drained below 50% of it's capacity (by leaving lights/stereo on), the life expectancy of the battery is severely diminished. As long as we don't let the battery drain, MB batteries last for 7+ years.
. Oh well, hopefully the battery will last another 8 years.
My 2005 C230 Kompressor Sports battery needs replacing.
After much searching found Glyn's other post at:
https://mbworld.org/forums/c-class-w...#ixzz3W4WYblCL
The original / current battery (part 10 A 003 541 73 01 = BATTERY 12V 74AH 680 CCA L 278 x W 178 x H 18 mm) has been replaced with (part 10 A 005 541 10 01 = AGM BATTERY 95 Ah 850 CCA)
There is a Varta AGM G14 (95 Ah 850 CCA) available in Aust. with exactly these same specifications as the replacement part referred to in Glyn's post in the link above.
Also it appears to be correct size L 353 x W 175 x H 190 mm.
Has the 95 Ah battery since been upgraded again to 100 Ah (as several posts all refer to 100 Ah) ?
The only AGM battery near that capacity (100 Ah) appears to be too large for my car = L of 393 mm (Varta H15 105 Ah 905 CCA),
Or non- AGM type (Varta Silver H3 100 Ah 830 CCA @ L 353 mm).
If I want to go with OEM is the Varta G14 the right one (95 Ah) and the right size ?
Looking to replace soon would appreciate some help please.
Last edited by hoops7; Apr 7, 2015 at 04:43 AM. Reason: insert missing bracket + make clearer + more relevant
W140 Mercedes S350, W221 S550 sport
Thanks for great info on site.
http://www.samsclub.com/sams/duracel...prod3590267.ip
$119
Specifications
Battery Electrolyte Composition:Acid
Battery End Type:Top Post
Battery Purpose:Starting Lighting Instrumentation
BCI Group Size:49
CA at 32 degrees F:1105
CCA at 0 degrees F:900
DIN code:H8/L5
Freight Class:65
Polarity:Right Positive
Reserve Capacity:185
Terminal Type
IN/SAEVolts:12
OR
http://www.samsclub.com/sams/auto-gr...uestid=4375412
$169
Specifications
20 amp hour rate:92
Battery Electrolyte Composition:Glass Mat
BCI Group Size:49
CA at 32 degrees F:975
CCA at 0 degrees F:850
DIN code:H8/L5
Freight Class:65
Reserve Capacity:170
Terminal Type
INVolts:12
AutoZone Duralast Platinum Battery
Other members will probably shame me for this, but when my last battery died on my 2003 C240 Wagon it put me in a tight spot. I needed an immediate fix. I grabbed the old core and hitched a ride to the corner AutoZone. Low and behold they had a suitable replacement in stock... a Duralast Platinum (H8-AGM):
http://www.autozone.com/batteries-st...?checkfit=true
It is advertised at 975 cranking amps (850 cold) and comes with a three year warranty. $175. Fits perfectly. Definitely not the most cost effective solution or necessarily the best, but very convenient. I have not had any issues with this battery and had a good experiences with one I installed on my previous BMW. If you find yourself in a pinch this battery will work nicely.
Keep'em Rolling,
zpbarnett
Keep'em Rolling,
zpbarnett
I didn't go OEM though. I went with Interstate MTP-H8 $182 plus $30 for install....
