things to do when warranty is close to expire?
Mine's about to run out in a few weeks so I took it in to fix the suspension bushings and to check the rest of the suspension out. Definitely look into an extended warranty for some piece of mind, though.
Check front castor bushes & watch out for cam magnets on the M272. Also make sure you have no timing chain rattle. Presume she's auto. Make sure the 722.9 7G is behaving properly. Some cars had bad speed sensors & the valve body required replacement - There is also a new "optimised" read Improved sump pan for the tranny & new spill tube. If all is well then leave well alone.
