Question about sparkplugs!
Old Jan 10, 2011 | 05:25 PM
Beffe's Avatar
C320 -03
Hello all, my first post here!
The other day I went to the store and bought twelve Bosch sparkplugs for my C320 -03.
But when I got home, I noticed that two of the sparkplugs didn`t have the same packaging as the other ten.
So, on two of the boxes it says Bosch Super Plus FR8DPP33+ Yttrium.
On the other ten it says Bosch Super Plus FR8DPP33+ Platinum / Iridium
All twelve sparkplugs has the same article number! (0 242 230 500)
Would this have any negative impact on the engine? Is it ok to use/mix them?
Hope you understand my question and my bad english, haha!
Regards
Christian
Old Jan 10, 2011 | 05:43 PM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
Since they all have the same part number, theoritically, it shouldn't cause any problem.
However, why take a chance? If I were you, I'd go back to the store and ask them for replacement of those 2 plugs to match with the remaining 10.
Old Jan 10, 2011 | 08:49 PM
ncmudbug's Avatar
2005 C230K, 2019 Honda CR-V, '74 Lotus Europa
Welcome!
They are probably ok. The "FR8DPP33+" is the significant thing to look at. That should be stamped in the steel part or lettered in the ceramic insulator. If they all match you should be ok. If you want to check further, you can check the length of threads to make sure they are all the same and you can check that the gap is set the same on all of them. Of course, they should visually look the same, but beyond that, checking much else would be pretty difficult.
Old Jan 11, 2011 | 09:36 AM
Glyn M Ruck's Avatar
Super Moderator
Christian - I think they are just newer & older versions of the same thing. For peace of mind get the store to give you 12 the same.
Old Jan 11, 2011 | 11:08 AM
OneOfaKindTrini's Avatar
Nike Turbo Shox
The other day I went into pep boys and bought twelve spark plugs and the guy asks what I need so many for I said thats how many my car uses.. He seriously followed me outside to what I drive.
Old Jan 11, 2011 | 12:22 PM
pcy's Avatar
pcy
may be he thought you have a 12 cylinder car :-)
Old Jan 11, 2011 | 02:33 PM
Super Moderator
You want to see the Tech's run when a V12 comes into the dealership I use for service.
Imagine if you had asked for 24 plugs
Old Jan 11, 2011 | 02:39 PM
Xhale707's Avatar
C320 2002
The V12's use 24 spark plugs...
Wowzers i thought 12 was a lot..
Old Jan 11, 2011 | 02:42 PM
Nike Turbo Shox
word hahaha ROFL. It would be funny if you went to a pep boys and ask for 24 sparkplugs and they tell you sorry sir I only have 18 lmao
Old Jan 11, 2011 | 03:08 PM
Xhale707's Avatar
C320 2002
They told me that when i had to buy lugnuts hahaha went to 4 different pepboys to collect them all
