Oil Leak
Old Jan 14, 2011 | 02:37 AM
jerryml430's Avatar
2006 c230
Oil Leak
Hey everyone, i just noticed today that there is oil leak on my car. I looked underneath the car and the only place i see the oil is under the oil pan. It's not a major oil leak but still, so do you guys have any idea what's causing the leak? I did an oil change about 3 months ago and they used the mobile 1 0w-40. I was thinking that they might forgot to tighten the screw or something
Old Jan 14, 2011 | 02:43 AM
e1000's Avatar
a quarter mile at a time
Most likely they re-used the copper crush washer on the drain plug instead of using a new one.
Old Jan 14, 2011 | 02:57 AM
samaritrey's Avatar
Super Moderator
THE C350
a picture is worth 1,000 words.
Old Jan 14, 2011 | 08:50 AM
MW_ATL's Avatar
'02 C230 Coupe (Me) '03 SLK320 6MT (Wife)
Yep, the picture would help, there are a couple of places it could leak. Mine started with the front crank seal leaking about 1K after a service. Completely unrelated, in my case and relatively inexpensive to fix.
Old Jan 14, 2011 | 01:55 PM
jerryml430's Avatar
2006 c230
I'll get under my car today after work and try to take some pictures
Old Jan 15, 2011 | 03:51 AM
jerryml430's Avatar
2006 c230
ok i did my best and thats all i could came up with
Old Jan 15, 2011 | 08:24 AM
fookoo303's Avatar
2003 c240
It's really hard to determine where that is. Did you remove the plastic underbody panel? If not, it's impossible to determine where the leak is coming from.
Old Jan 15, 2011 | 10:23 AM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
^ +1.
Looks like the pictures were taken with out removing the plastic underbody panels.
Please re-take the pictures with those panels removed.
Old Jan 15, 2011 | 11:07 AM
Ribo89's Avatar
a Tank
^^^^Take of the plastic cover, clean the area, wait a few hours and see where the oil is coming from. I had a recent oil leak 2....the oil pan screw and the copper washer were the problem...Luckily i needed an oil change, so it was an easy fix.
Old Jan 16, 2011 | 03:32 AM
jerryml430's Avatar
2006 c230
My bad, there we go. i just took the cover out and here what i found
Old Jan 16, 2011 | 04:40 AM
ND2020's Avatar
2004 C320 Sport
Looks to be the copper crush washer. Like e1000 said, they probably reused the old one instead of replacing it like they should've. Get a new washer and torque to spec.
Old Jan 16, 2011 | 05:03 AM
jerryml430's Avatar
2006 c230
will do, thank you all for your help
Old Jan 16, 2011 | 12:30 PM
pcy's Avatar
pcy
in the posted picture (above), I don't see the copper crush washer at all. My guess is that whoever did the oil change, they didn't even put the copper washer.
Old Jan 16, 2011 | 02:29 PM
jerryml430's Avatar
2006 c230
Good year place did the job, and they charged me $136. I'm not going there anymore
Old Jan 16, 2011 | 02:46 PM
e1000's Avatar
Do you know what kind of oil they used? Probably a good idea to stay away from thaty place.
Old Jan 16, 2011 | 03:26 PM
MW_ATL's Avatar
+1 That would make me really wonder what else they didn't do right. "Oh, this oil will be fine, it is close enough to what it calls for."
Old Jan 16, 2011 | 04:14 PM
jerryml430's Avatar
2006 c230
I requested the mobile 1 0W-40, and I was looking at the paper work and it said that they used about 9 thing of mobile 1 0W-40 and they charge me about $10 for each
Old Jan 16, 2011 | 05:14 PM
pcy's Avatar
pcy
You will need to remove the drain bolt, put in a new crush washer and you will need to put the drain bolt back on. When you remove the drain bolt, all of the oil will come out - you will have to decide if you want to collect the oil in to a container and pour it back in to the engine OR pour new oil.
When the Goodyear folks changed the oil, what kind of oil filter did they use? paper media type or fleece material filter?
Old Jan 16, 2011 | 05:15 PM
pcy's Avatar
pcy
By the way, you can buy a set (100) of assorted sizes copper washers from Harbor Freight for $4 or so.
Old Jan 16, 2011 | 05:18 PM
OneOfaKindTrini's Avatar
Nike Turbo Shox
If possible you should do the oil change yourself.
samaritrey's Avatar
Super Moderator
THE C350
I would just replace all the oil just so you know that it was done right with the correct filter.
Old Jan 16, 2011 | 05:44 PM
Mercury's Avatar
2005 1.8 B/B
I just did my oil change today.
How come mine does not have a washer, just the bolt itself.
Is it necessary to have it?
BTW I have 2005 C230.
Old Jan 16, 2011 | 07:23 PM
samaritrey's Avatar
Super Moderator
THE C350
they all should have the 14 cent crush washer. and you have to replace it every time you do an oil changer or you will have problems. Heck when i did mine this way i replaced the bolt to because i could tell someone did not put it back on right way overtightened and rounded off some. rmeuropean has both for less then $2 lol
Old Jan 16, 2011 | 07:46 PM
jerryml430's Avatar
2006 c230
If i'm not mistaken they used fram fleece oil filter, it sucks that I have to waste the oil now. I barely got the oil change, its only 2 months. I'm thinking to check if dinan still doing the free oil change, since I live close to campbell
Old Jan 16, 2011 | 08:08 PM
fookoo303's Avatar
2003 c240
don't waste it. bring it back to them and show it to them. They should be more than inclined to remedy it, and you won't have wasted 130 dollars.
